New RFLink firmware (R45) now available!
Posted: Wednesday 07 December 2016 17:01
R45 Changelog:
- New Device: Silvercrest switch set IAN276299
- New Device: Silvercrest switch set IAN113854
- New Device: Silvercrest switch set IAN91210
- New Device: Quigg switch set GT-9000 (Tevion/Globaltronics/ALDI)
- New Device: Unitec switch set 4811 model 50028 (Intertek)
- New Device: Cotech switch set 36-6361
- New Device: Sartano switch set, Model 50028, HN 10047
- New Device: Electro Depot switch set, article code 940557
- New Device: BL999 weather sensor
- New Device: Digi-Tech 4-LD14554 Outdoor temperature sensor (Thanks: PJA)
- New Device: PLC-T4022G X10 RF to Powerline
- New Device: X10 UR76 E Remote Control
- New Device: Konig Alarm system sensors
- New Device: Alecto 1200 alternative protocol version
- New Device: Oregon EW99
- New Device: Smartwares RM174RF Smoke detector
- New Device: FirstLine FWS802 Pool Thermometer (Thanks: BC)
- New Device: Liwin Shutters / Blinds controller
- Fixed: MiniGPIO command structure
- Fixed: Conrad RSL pair command added
- Fixed: Warema EWFS (Thanks: SH)
- Fixed: Removed Ningbo debug message
- Fixed: Mebus protocol detection for Auriol Z29536 IAN55982
- Fixed: Removed debug messages on Atlantic protocol
- Fixed: Milight color and brightness changing on groups
- Fixed: DKW2012 Humidity conversion
- Fixed: DKW2012 Wind speed conversion (Thanks: HJ)
- Fixed: Xiron ID sometimes had an incorrect bit
- Fixed: Blyss/Avidsen transmit
- Fixed: Aster protocol split on/off and dim/bright into separate devices
- Fixed: Improved detection of WH5029
- Fixed: Improved HE800 protocol detection
- Fixed: Improved detection of Cleverwatts, Kerui and compatible devices
- Fixed: Proper handling of incoming serial commands for KAKU and related devices
- Fixed: Improved Chacon EMW200 detection
- Added: RTS protocol option to swap ON/OFF command
- Added: RTS long TX option to extend the RTS transmit time
- Added: "Settings reset" feature
- Added: Extended Gaposa protocol
- Added: Lacrosse V3 protocol support for negative temperature values
Available on www.nemcon.nl/blog2
Enjoy!
Enjoy!
