New RFLink firmware (R45) now available!
- Stuntteam
R45 Changelog:
- New Device: Silvercrest switch set IAN276299
- New Device: Silvercrest switch set IAN113854
- New Device: Silvercrest switch set IAN91210
- New Device: Quigg switch set GT-9000 (Tevion/Globaltronics/ALDI)
- New Device: Unitec switch set 4811 model 50028 (Intertek)
- New Device: Cotech switch set 36-6361
- New Device: Sartano switch set, Model 50028, HN 10047
- New Device: Electro Depot switch set, article code 940557
- New Device: BL999 weather sensor
- New Device: Digi-Tech 4-LD14554 Outdoor temperature sensor (Thanks: PJA)
- New Device: PLC-T4022G X10 RF to Powerline
- New Device: X10 UR76 E Remote Control
- New Device: Konig Alarm system sensors
- New Device: Alecto 1200 alternative protocol version
- New Device: Oregon EW99
- New Device: Smartwares RM174RF Smoke detector
- New Device: FirstLine FWS802 Pool Thermometer (Thanks: BC)
- New Device: Liwin Shutters / Blinds controller
- Fixed: MiniGPIO command structure
- Fixed: Conrad RSL pair command added
- Fixed: Warema EWFS (Thanks: SH)
- Fixed: Removed Ningbo debug message
- Fixed: Mebus protocol detection for Auriol Z29536 IAN55982
- Fixed: Removed debug messages on Atlantic protocol
- Fixed: Milight color and brightness changing on groups
- Fixed: DKW2012 Humidity conversion
- Fixed: DKW2012 Wind speed conversion (Thanks: HJ)
- Fixed: Xiron ID sometimes had an incorrect bit
- Fixed: Blyss/Avidsen transmit
- Fixed: Aster protocol split on/off and dim/bright into separate devices
- Fixed: Improved detection of WH5029
- Fixed: Improved HE800 protocol detection
- Fixed: Improved detection of Cleverwatts, Kerui and compatible devices
- Fixed: Proper handling of incoming serial commands for KAKU and related devices
- Fixed: Improved Chacon EMW200 detection
- Added: RTS protocol option to swap ON/OFF command
- Added: RTS long TX option to extend the RTS transmit time
- Added: "Settings reset" feature
- Added: Extended Gaposa protocol
- Added: Lacrosse V3 protocol support for negative temperature values
Available on www.nemcon.nl/blog2
Enjoy!
Enjoy!
- Target OS: -
Re: New RFLink firmware (R45) now available!
Great work!! Will try this weekend, thanks Stuntteam!
I've updated to 45, but noticed some of my on/off commands are reversed..... anyone else noticed this?
Great, thanks!
Any support for Visonic devices on 433 and 868?
Currently I'm getting respons on 868 as a Atlantic device but it is not very accurate.
regards, Jeroen
regards, Jeroen
- Stuntteam
mail me a debug log and we will fix it..
doneStuntteam wrote:mail me a debug log and we will fix it..
appreciate your effort in advance
- Domoticz version: 3.8153
Firmware 43 is last one working for me.. If i flash R44 or new R45 it shows firmware version in loader but :10 status and :20 dont give any response in log and no signals show up in log and domoticz doesnt see rflink or firmware version and cant controll
Adruino mega 2560 clone and nodeshop rf gateway 1.14
What has changed and how can i fix it?
- Domoticz version: Latest
Great thanks! My MiLight problem (in version R44) is fixed in R45.
Nice job!
Nice job!
Many thanks Stuntteam !! Great job.
- phoenixblue
Re: RE: Re: New RFLink firmware (R45) now available!
Here same problem, the 2 orange and the one green led are on but see in the log file nothing received.D3LTA wrote:Firmware 43 is last one working for me.. If i flash R44 or new R45 it shows firmware version in loader but :10 status and :20 dont give any response in log and no signals show up in log and domoticz doesnt see rflink or firmware version and cant controll
- sincze
- Domoticz version: 2024.4
Flashed R45 with domoticz and arduino mega clone. Log works domoticz as well. Seems I have to choose.. Mysensors or Milight.. Not both. Simultaneously. I choose milight as I have a mysensors Gateway as well.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Domoticz version: latest
Flashed R45 and I realized my Tunex temp and humidity (identified as wtgr800) sensors disappearing sometimes. After 2 minutes or a week, but always disappearing and I have to pair again. Is there a solution for this?
- Stuntteam
Make a debug log as explained here: http://www.nemcon.nl/blog2/development
and mail that to [email protected]
I have the same problem as you have.D3LTA wrote:Firmware 43 is last one working for me.. If i flash R44 or new R45 it shows firmware version in loader but :10 status and :20 dont give any response in log and no signals show up in log and domoticz doesnt see rflink or firmware version and cant controll
Using a mega 2560 clone and R43 works just fine but R44 and R45 just don't work for me.
I've ordered another Arduino to see if that will fix the problem.
Only difference I've seen is the addition of extra protocols that are supported.
In this FW was Added: "Settings reset" feature.
How i can use it ?
Maybe good feature will be add button to Domoticz to reset RFLink ?
How i can use it ?
Hi there,
I've upgrade to the firmware because I have 4 Smartwares RM174RF Smoke detectors. They are added in this firmware, but how do I connect them. I can't find them in devices. And unable to find them when I add a new switch.
Please help.
Please help.
cryonic90 wrote:I have the same problem as you have.D3LTA wrote:Firmware 43 is last one working for me.. If i flash R44 or new R45 it shows firmware version in loader but :10 status and :20 dont give any response in log and no signals show up in log and domoticz doesnt see rflink or firmware version and cant controll
Shorting pin 12/13 will fix the issue.. It clears eeprom and all working fine now for me
same issue here, I just bought Smartwares RM174RF Smoke detectors because they would work with RFLink and domoticz but they don't show up in the debug log or in the application...
I tried just testing them seperately and paired but no log info
Indeed, this works, thanks!D3LTA wrote:cryonic90 wrote:I have the same problem as you have.D3LTA wrote:Firmware 43 is last one working for me.. If i flash R44 or new R45 it shows firmware version in loader but :10 status and :20 dont give any response in log and no signals show up in log and domoticz doesnt see rflink or firmware version and cant controll
Sent from my Xperia Z3 Tablet Compact using Tapatalk
You welcome
