hello,
It would be very nice to add roomplan support to blocky, or way to show hide switches (maybe only add hidden/visible operator).
I have few switches that are usefull only in some condition and this would be great way to make stuff clean.
Blocky add show hide switch
Re: Blocky add show hide switch
I have the same question (I think), can I hide/show switches depending on their status (e.g. on -> show)? I know that if I add $ to the beginning of the switch name is will become hidden but how can I do that from a script?
For me it's find using lua (preferably dzVents).
- Egregius
- Domoticz version: v2024.7
Use the developer console of a good browser to find the url.
You can change the name with a url like this (from Switches tab):
From the device table the url is even cleaner:
Attention: renaming a device requires that your scripts work with both NAMEOFSWITCH and $NAMEOFSWITCH
Could be a difficult way to go...
http://192.168.2.10:8084/json.htm?type=setused&idx=5&name=NAMEOFSWITCH&description=&strparam1=&strparam2=&protected=false&switchtype=0&customimage=5&used=true&addjvalue=0&addjvalue2=0&options=
http://192.168.2.10:8084/json.htm?type=command¶m=renamedevice&idx=5&name=NAMEOFSWITCH
Great - thanks!
In my script (dzVents) I'm using the ID to identify the switch and hopefully avoid problems with different names...
--'Test_Switch',
--'$Test_Switch',
3
execute = function(domoticz,switch)
