EQ3 MAX! - LUA Socket Connect Failed
knifto2
Post by knifto2 »
I installed the required components via;
https://www.domoticz.com/wiki/EQ3_MAX!
(had some problems described with openssl)
Output of
sudo luarocks list
Installed rocks:
basexx
0.3.0-1 (installed) - /usr/local/lib/luarocks/rocks
luasec
0.6-1 (installed) - /usr/local/lib/luarocks/rocks
luasocket
3.0rc1-2 (installed) - /usr/local/lib/luarocks/rocks
When I try to fire up the test script it failes;
Socket connect failed for 192.168.88.238:62910
I can ping the device from IP and DNS name, I tried both in the test-script.
