Blockly separate tests for trigger and current status
wormiedk
Post by wormiedk »
As far as I understand blocky the event that "triggers" the blocky has to be first in the if statement e.g. the following should get triggered if dev1 changes state only if ItsDark is set to on. However ItsDark does not have to change state:
IF dev1=On and ItsDark=On
I also assume that the following would not work as it would require ItsDark to change state before checking the status of dev1 :
IF ItsDark=On and dev1=On
I think it would be more clear if there were two kind of comparisons e.g.:
If dev1 changes to On and ItsDark is On
Also the new If/Then/Else block is great and allows for nested ifs e.g.
If ItsDark=On then
If dev1=On then
However this structure does not get triggered if dev1 changes while it is dark as it requires ItsDarks state to change.
Please let me know if the above is correct as it would explain many of my problems using blocky.
Cheers
David
