I just installed a danalock V2.
I can include it in Zwave just fine, and find an "access control" device, but it does not work nor update its status, when I lock using bluetooth I can see in the domoticz log that it changes state to "secure",
OpenZWave: Alarm Level: Secure
but the device in domoticz does not update.
when clicking the icon in domoticz it is unable to transmit:
Admin initiated a switch command (1205/Access Control/Off)
2016-11-30 14:46:19.678 Error: OpenZWave: Internal Node ValueID not found! NodeID: 23 (0x17), instanceID: 52
23 (0x17) is the lock, no idea what instanceID is...
has anyone got a danalock to work?
Danalock V2 compatibility issues
smedberg
Re: Danalock V2 compatibility issues
I got it to working with 3.5877 using this guide viewtopic.php?f=17&t=11316&p=81802&hili ... ock#p81802
But the status of the lock is inverted
ArturK
Can you check how your danalock changes its state? In my case changes 2 times in every move. It works exactly like this:smedberg wrote: Sunday 08 January 2017 15:45 I got it to working with 3.5877 using this guide viewtopic.php?f=17&t=11316&p=81802&hili ... ock#p81802
Closing or opening the lock using the Danalock application via Bluetooth causes the lock status to be correct in Domoticz, so it is ok.
Closing or opening the lock using the switch in Domoticz (light switch or door lock) - the status immediately changes to the opposite when clicking switch, but it is a mistake, because the lock needs a few seconds to do the job.
When movement is finished, the status changes to the opposite again (it takes 13 sec). The result is that when closing or opening Danalock, the status changes 2 times, so after doing the job is like before. Even enable polling does not fix the problem.
Someone solved this problem?
Raspberry Pi 2B, Logitech Harmony Hub, Z-Stick GEN 5.
