Input box for variable
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi there Domoticz friends,
Since we are away a lot of weekends to the Belgian coast I have made some code to heat up my house gradually before we travel home again.
Idea is that I switch a dummy to start up the code.
What I would like to have is a pop up input box where I can give the starting and end time.
Is this possible?
The code:
setpoint = tonumber(otherdevices_svalues['Room Setpoint'])
werkelijk= tonumber(otherdevices_svalues['Room Temperature'])
uur = tonumber(os.date("%H"));
minuten = tonumber(os.date("%M"));
seconden = tonumber(os.date("%S"));
dagtemp   = uservariables["dagtemperatuur"]
for i=9,20,1 do
    if (uur== i and minuten==5 and seconden==0 and setpoint<=dagtemp) then
        print ("sec=  "..seconden.." i= "..i)
        setpoint=setpoint+0.5
		set = "6|0|" .. setpoint
		commandArray ['UpdateDevice']= '6|0|' .. setpoint
Thnx for any advice.
Jan
JuanUil
Re: Input box for variable
Post by JuanUil »
anybody any idea?
Nautilus
Post by Nautilus »
I'm using a script to make sure the car has heated for a proper time (based on outside temperature) before leaving the house. The next departure time is stored as a user variable. For Android there is an app with which you can update domoticz user variables, but for iOS there currently isn't any. So I made a simple .php page with input form (containing a time picker drop-down list) and a submit button that will then trigger the json to update the user variable value. I think something like this is the closest you can get - at least easily. You can have this page available under the "Custom" tab in Domoticz if you store the page under ../domoticz/www/templates
JuanUil
Post by JuanUil »
Hi Nautilus,
tnx for your reply. could you post me your solution because it looks good but i am not skilled in php programming.
thank you in advance.
Jan
Nautilus
Post by Nautilus »
Well, I think there no use in copying mine but something like this could get you started:
Add form with input box and submit button:
<!DOCTYPE html>
<html>
<form name="single2" method="POST" action="">
	<input type="text" value="" id="timer2" name="timer2" />
	<input type="submit" name="submit2" value="Submit">
</form>
</html>
React to pressing the submit button ( = update uservariable):
<?php
if(isset($_POST['submit2'])){
	$timer2 = urlencode($_POST['timer2']);}
	file_get_contents('http://domoticzurl:port/json.htm?type=command&param=updateuservariable&vname=VARIABLENAME&vtype=2&vvalue='.$timer2);
Then it is up to you what else and what kind of formatting you want to have there...:)
JuanUil
Post by JuanUil »
Thank you, I will work on it this weekend. For a start it is oké!
