PiFace input problem
happyman
Post by happyman »
I'm using a PiFace board on my RaspberryPi3. It is working fine.
I use 4 outputs, 2 ON/OFF switches and 1 button. This works fine.
Today I wanted to add another input switch, but then something strange happens.
It is an normal ON/OFF Switch with 5mtr of coax cable.
When the contact is made, it is shown in domoticz.
When the contact is open (after it was made) the input in domoticz keeps switching on and off.
When I disconnect the cable it stops.....
The piface.conf file is build like this.
piface.0.input.3.enabled=true
piface.0.input.3.pin_type=level
piface.0.input.3.count_enabled=false
piface.0.input.3.count_type=generic
piface.0.input.3.count_update_interval_sec=1
Anyone an Idea?
happyman
Re: PiFace input problem
Post by happyman »
After lots of possible solutions I inserted a resistor in serie and the problem seems to be over.
peterjoosen
Domoticz version: 4.9700
Post by peterjoosen »
Can you tell me what resistor(=??? Ohm) you used to solve the problem?
Best regards,
Peter
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
The contact must connect the input to the ground. The circuit must have as little resistance as possible.
Jan Jansen
I use:
piface.1.input.1.enabled=true
piface.1.input.1.pin_type=level
piface.1.input.1.count_enabled=false
piface.1.input.1.count_update_interval_sec=10
happyman
Post by happyman »
peterjoosen wrote: Thursday 01 June 2017 23:10 Hello,
Best regards,
Peter
I used a 4k7 resistor.
