Can't open HTTPS URL:s using LUA script
Posted: Monday 28 November 2016 16:24
by BakSeeDaa
Version: 3.5877
Platform: Raspberry Pi 3B
Description:Error opening https URL:s when MQTT HW Device is removed
Hi there. I needed to clean up my installation a bit.
I installed the latest Raspbian Jessie Lite SD card image today followed by installing Domoticz. After that I restored the Domoticz database from a backup.
I have one issue that I can not solve. I had been experimenting with MQTT before and I had a MQTT hardware (MQTT Client Gateway with LAN Inteface) defined. After doing the re-installation I get error messages in the log:
Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
So, to get rid of that problem I disabled the MQTT hardware and the error messages disappeared. I don't need MQTT. However when I disable (or remove ) the MQTT Hardware I get a new problem.
Using LUA,
commandArray['OpenURL']='http://www.gp.se' works fine but
commandArray['OpenURL']='https://www.gp.se' fails with the error: Error: Error opening url:
https://www.gp.se
I will be so happy for any kind help to solve this issue. Thanks!
Re: Error opening https URL:s when MQTT HW Device is removed
Posted: Monday 28 November 2016 17:32
by gizmocuz
Thats correct, with the new install method, you need to install additional software yourself, like the mosquito mqtt broker
this might work:
apt-get install mosquitto
Re: Can't open HTTPS URL:s using LUA script
Posted: Monday 28 November 2016 18:07
by BakSeeDaa
gizmocuz wrote:Thats correct, with the new install method, you need to install additional software yourself, like the mosquito mqtt broker
this might work:
Thanks @gizmocuz for Your kind help.
Just to be sure, Do I need to install the mosquito mqtt broker even though I don't wish to use MQTT? (I just want to be able to run commandArray['OpenURL'] using https )
Posted: Monday 28 November 2016 21:49
by BakSeeDaa
Maybe my questions sounds so weird... Yes, I'm still confused about this, I'm sorry for my ignorance.
Is it really necessary to define a "MQTT Client Gateway with LAN interface" hardware and to install mosquitto if I like to use LUA script to open a HTTPS URL using the commandArray (E.g. commandArray['OpenURL']='
https://somesite.com')
Posted: Tuesday 29 November 2016 7:04
by bizziebis
I think it's a certificate problem. You are trying to set up a secure connection so a valid certificate is expected. If you use a URL with a self-signed certificate its possible it doesn't work.
If you use the os.execute command you would issue a 'curl -k htps://....' command to ignore the SSL certificate.
Posted: Tuesday 29 November 2016 10:26
by BakSeeDaa
bizziebis wrote:I think it's a certificate problem. You are trying to set up a secure connection so a valid certificate is expected. If you use a URL with a self-signed certificate its possible it doesn't work.
Thank You.
No, the problem is not the server certificate on the target host.
Summarizing
Issuing the following command from the command line works great:
While the following LUA script will fail
if (devicechanged['script_device_test'] == 'On') then
commandArray['OpenURL']='https://www.google.se/'
From the Domoticz error log:
Error: Error opening url: https://www.google.se/
And to make everything more obscure... (sorry for that)
-If I create a "MQTT Client Gateway with LAN interface" hardware, the same LUA script above works fine. But I don't want to have a MQTT Client Gateway.
Current workaround solution:
I've made a LUA function used for calling URL:s
function OpenURL(url)
if (string.find(url, 'https')) then
os.execute('curl -s \'' .. url .. '\' > /dev/null 2>&1 &')
commandArray[#commandArray+1]={['OpenURL']=url }
