Can't open HTTPS URL:s using LUA script
BakSeeDaa
Post by BakSeeDaa »
Version: 3.5877
Platform: Raspberry Pi 3B
Description:Error opening https URL:s when MQTT HW Device is removed
Hi there. I needed to clean up my installation a bit.
I installed the latest Raspbian Jessie Lite SD card image today followed by installing Domoticz. After that I restored the Domoticz database from a backup.
I have one issue that I can not solve. I had been experimenting with MQTT before and I had a MQTT hardware (MQTT Client Gateway with LAN Inteface) defined. After doing the re-installation I get error messages in the log:
 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
So, to get rid of that problem I disabled the MQTT hardware and the error messages disappeared. I don't need MQTT. However when I disable (or remove ) the MQTT Hardware I get a new problem.
Using LUA, commandArray['OpenURL']='http://www.gp.se' works fine but commandArray['OpenURL']='https://www.gp.se' fails with the error: Error: Error opening url: https://www.gp.se
I will be so happy for any kind help to solve this issue. Thanks!
Last edited by BakSeeDaa on Monday 28 November 2016 21:52, edited 1 time in total.
gizmocuz
Re: Error opening https URL:s when MQTT HW Device is removed
Post by gizmocuz »
Thats correct, with the new install method, you need to install additional software yourself, like the mosquito mqtt broker
this might work:
apt-get install mosquitto
BakSeeDaa
Re: Can't open HTTPS URL:s using LUA script
Post by BakSeeDaa »
gizmocuz wrote:Thats correct, with the new install method, you need to install additional software yourself, like the mosquito mqtt broker
this might work:
Thanks @gizmocuz for Your kind help.
Just to be sure, Do I need to install the mosquito mqtt broker even though I don't wish to use MQTT? (I just want to be able to run commandArray['OpenURL'] using https )
Last edited by BakSeeDaa on Monday 28 November 2016 21:53, edited 1 time in total.
BakSeeDaa
Post by BakSeeDaa »
Maybe my questions sounds so weird... Yes, I'm still confused about this, I'm sorry for my ignorance.
Is it really necessary to define a "MQTT Client Gateway with LAN interface" hardware and to install mosquitto if I like to use LUA script to open a HTTPS URL using the commandArray (E.g. commandArray['OpenURL']='https://somesite.com')
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
I think it's a certificate problem. You are trying to set up a secure connection so a valid certificate is expected. If you use a URL with a self-signed certificate its possible it doesn't work.
If you use the os.execute command you would issue a 'curl -k htps://....' command to ignore the SSL certificate.
BakSeeDaa
Post by BakSeeDaa »
bizziebis wrote:I think it's a certificate problem. You are trying to set up a secure connection so a valid certificate is expected. If you use a URL with a self-signed certificate its possible it doesn't work.
Thank You.
No, the problem is not the server certificate on the target host.
Summarizing
Issuing the following command from the command line works great:
curl https://www.google.se
While the following LUA script will fail
if (devicechanged['script_device_test'] == 'On') then
	commandArray['OpenURL']='https://www.google.se/'
From the Domoticz error log:
Error: Error opening url: https://www.google.se/
And to make everything more obscure... (sorry for that)
-If I create a "MQTT Client Gateway with LAN interface" hardware, the same LUA script above works fine. But I don't want to have a MQTT Client Gateway.
Current workaround solution:
I've made a LUA function used for calling URL:s
function OpenURL(url)
		if (string.find(url, 'https')) then
			os.execute('curl -s \'' .. url .. '\' > /dev/null 2>&1 &')
			commandArray[#commandArray+1]={['OpenURL']=url }
