Error:1wire: Device not yet supported...
Posted: Sunday 27 November 2016 21:35
by domer
I've been running domoticz with 1wire for a quite while now but recently stumbled upon this error:
"Error: 1Wire: Device not yet supported in Kernel mode (Please report!) ID:not found., family: 00"
Any ideas what has happened? I havent done anything with the system that could have caused this so is this software issue or something with my 1wire devices?
Posted: Sunday 27 November 2016 23:12
by antwan
Is There info in the Field?
OWFS Path:
Do you use 1 wire via raspberrypi?
Re: Error:1wire: Device not yet supported...
Posted: Monday 28 November 2016 11:18
by domer
Yes forgot to mention that I'm using raspberry pi 3. I haven't yet examined this very thoroughly but I noticed that none of the devices were found in the /sys/bus/w1/devices. What do you mean with OWFS paths? Something found in config files or?
Posted: Monday 28 November 2016 19:01
by antwan
In hardware settings
Posted: Tuesday 29 November 2016 18:20
by domer
managed to find the source of my problem and it was faulty? pull up resistor. Replaced it with a new one and bus started working again \o/. OWFS path was empty but after resistor change it changed to /mnt/1wire.
Thanks for help!
