I've been running domoticz with 1wire for a quite while now but recently stumbled upon this error:
"Error: 1Wire: Device not yet supported in Kernel mode (Please report!) ID:not found., family: 00"
Any ideas what has happened? I havent done anything with the system that could have caused this so is this software issue or something with my 1wire devices?
Error:1wire: Device not yet supported... Topic is solved
Moderators: fantom, leecollings
antwan
- Domoticz version: Latest
Is There info in the Field?
OWFS Path:
Do you use 1 wire via raspberrypi?
OWFS Path:
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
domer
Re: Error:1wire: Device not yet supported...
Yes forgot to mention that I'm using raspberry pi 3. I haven't yet examined this very thoroughly but I noticed that none of the devices were found in the /sys/bus/w1/devices. What do you mean with OWFS paths? Something found in config files or?
antwan
In hardware settings
domer
managed to find the source of my problem and it was faulty? pull up resistor. Replaced it with a new one and bus started working again \o/. OWFS path was empty but after resistor change it changed to /mnt/1wire.
Thanks for help!
Thanks for help!
