Gas Youless: decimal point wrong
Posted: Saturday 26 November 2016 12:18
by krommetje3108
I have 2 youless devices, one for electricity and the other for natural gas. Domoticz reads the youless for natural gas correct however the decimal point is wrong. The current measurement reads 9855.410 but domoticz reports: 98554.10
A leading zero in front in the youless doesn't work.... what can I do to correct this?
Re: Gas Youless: decimal point wrong
Posted: Friday 09 December 2016 21:41
by HSR3
I have the Youless gas sensor since a few days and have the same issue (version 3.5877). Changing the number of pulses/m3 in the Youless configuration doesn't help either.
It would be nice if this could be fixed, the usage in Domoticz is now 10 times higher than real. Besides this the Domoticz panel shows the current usage as m3 while the Youless displays the usage in l/u. 2955 m3 is the amount of gas I am using in 3 years. ;)
Two screenshots to illustrate the issue.
Posted: Sunday 01 January 2017 18:06
by HSR3
I finally found how to fix the decimal position of the youless gas sensor. In the Meter/Counter tab of the Settings page you can set the conversion of the input. In my situation I had to change the setting from 100 to 1000. Now the Youless reading is correct.
