universal Time Difference Script
emme
Domoticz version: latest
Post by emme »
Ciao,
I'm creating a LUA script file that includes all the common routine that can be used in the event scripting in lua without defining them all the times
The file script is named LibUtil.LUA and at the moment include Time difference (as per wiki) and a conversion from CSV to table
the file is called in each script as:
libutil = loadfile "/home/pi/domoticz/scripts/lua/LIBUTIL.lua"()
than you can call different routines like
libutil:timeDiff(s)
the time difference function has been changed a little to be considered... universal..
here's mine:
function timeDiff(dName,dType)
    t1 = os.time()
    if dType == 'v' then
        updTime = uservariables_lastupdate[dName]
    elseif dType == 'd' then
        updTime = otherdevices_lastupdate[dName]
    year = string.sub(updTime, 1, 4)
    month = string.sub(updTime, 6, 7)
    day = string.sub(updTime, 9, 10)
    hour = string.sub(updTime, 12, 13)
    minutes = string.sub(updTime, 15, 16)
    seconds = string.sub(updTime, 18, 19)
    tDiff = os.difftime(t1,t2)
    return tDiff
the function has 2 arguments: device name and device type: V for a variable, D for a device
in this way I can test both cases with a single function
now I will defice and call this way:
varName = 'MyVariable'
devName = 'MyDevice'
    secsDevice = libutil:timeDiff(devName,'d')
    secsVariable = libutil:timeDiff(varName,'v')
    print ( "Time difference for Device '..devName..': '..secsDevice..' - for Variable '..varName..': '..secsVariable)
...in case you add the function in each script it could even not need that, but if you willing to create a library.. it could be useful
Hope this could help someone
ciao
M
"We always done this way"
Users browsing this forum: hjzwiers and 1 guest
