WanIP Checker
Posted: Friday 25 November 2016 9:24
by emme
Ciao,
Due to some requirements I have I've wrote a script to get and eventually update the Wan IP Address.
my provider use not to change the public IP unless the IAD at my home is resetted or remotely upgraded, but since I'm evaluating to remove the ddns and connect just using the externa IP, I was seeking for a way to obtain it.
So I've created a Variable named WanIP_IP and a script that trigger a bash command and do the rest...
here is it
VARNAME = 'WanIP_IP'
GETIP = 'curl -s https://4.ifcfg.me/'
TMPFILE = '/home/pi/domoticz/scripts/wanip.txt'
PTPPREFIX = '>>> [WanIP checker] >>> '
IDLESECS = 21600 -- 6 hours
function timeDiff(dName)
    t1 = os.time()
    updTime = uservariables_lastupdate[dName]
    year = string.sub(updTime, 1, 4)
    month = string.sub(updTime, 6, 7)
    day = string.sub(updTime, 9, 10)
    hour = string.sub(updTime, 12, 13)
    minutes = string.sub(updTime, 15, 16)
    seconds = string.sub(updTime, 18, 19)
    tDiff = os.difftime(t1,t2)
    return tDiff
CURRWNIP = uservariables[VARNAME]
IDLETIME = tonumber(timeDiff(VARNAME))
    if IDLETIME > IDLESECS then
        os.execute(GETIP..' > '..TMPFILE)
        wanip = io.open(TMPFILE):read()
        if not wanip then
            print (PTPPREFIX..'impossibile reperire Wan IP')
            if wanip ~= CURRWNIP then
                print (PTPPREFIX..'Agiornamento WAN IP: '..wanip)
                commandArray['Variable:'..VARNAME] = wanip
                os.execute('rm /home/pi/domoticz/scripts/wanip.txt')
It's a TIME:EVENT script and runs every 6 hours (set by IDLESEC), get the external IP, check for differences in case and eventually update
than I have a variable script that notify me the change via Telegram and email.
With many thanks to @egregius... I think in bash this can be done in this way:
#!/bin/bash
LASTWANIP =`cat /tmp/lastwanip.txt`
NEWWANIP = `curl -s https://4.ifcfg.me/`
if [[ $LASTWANIP -ne $NEWWANIP ]];then
   echo $NEWWANIP > /tmp/lasttemp.txt
   DOMOTICZ=`curl -s "http://127.0.0.1:8080/json.htm?type=command&param=updateuservariable&vname=WanIP_IP&vtype=string&vvalue=$NEWWANIP
fi
and it could be sets as a cron job
ciao
M
Re: WanIP Checker
Posted: Friday 25 November 2016 11:35
by remb0
Great work! can you add it to the wiki? same account as forum.
that way all info is saved in a central place.
Re: WanIP Checker
Posted: Friday 25 November 2016 11:37
by emme
uh.. really?!
REALLY REALLY?!?! :shock: :o :mrgreen:
Will do this during the weekend (my office firewall blocks Domoticz Wiki :( )
Re: WanIP Checker
Posted: Friday 25 November 2016 12:41
by remb0
:) thanks!
I should look for another job :P one that allow domoticz sites :)
Re: WanIP Checker
Posted: Friday 25 November 2016 17:33
by Egregius
You should ass something that sends you the new ip address. How will you now it if it's changed and you can't access domoticz anymore?
Great that you provide it in 2 languages!
I think it's better to use the shell version, what if the ip is changed and domoticz is crashed so it can't sent you anything? Then you don't have the external address to do anything.
Re: WanIP Checker
Posted: Friday 25 November 2016 17:41
by emme
the IP event in domoticz is a time event, but triggers the check on 6 hour basis (it is setted by the IDLESECS local variable)
I have another Variable event that sends me the notification of the new IP (of the variable change)
The bash is intend to be a cron job and can run every hour and can be also include a sendmail command for notifying the change
Re: WanIP Checker
Posted: Monday 07 August 2017 21:54
by HM31
Here is an adaptation to Domoticz installed on Synology (essentially the temp file has to be moved elsewhere ... and translation in French for messages ... not necessary but easier for me ! :lol: )
TMPFILE = '/volume1/@appstore/domoticz/var/scripts/wanip.txt'
IDLESECS = 1800  -- 30 mn
    t1 = os.time()
    return tDiff
        if not wanip then
            print (PTPPREFIX..'Impossible de récupérer WAN IP')
                print (PTPPREFIX..'Actualisation de WAN IP: '..wanip)
                os.execute('rm /volume1/@appstore/domoticz/var/scripts/wanip.txt')
Next step, updating a general, text dummy switch with the value, thus doing quite the same thing as this thread https://www.domoticz.com/forum/viewtopi ... 65&t=16266, that was initialy inspired by emme
Re: WanIP Checker
Posted: Friday 10 November 2017 16:54
by emme
Ciao,
since my plugin won't work anymore, I've re-wrote the wanIP checker under dzVents:
            timer = { 'every 6 hours' }
	logging = {
            level = domoticz.LOG_FORCE,
            marker = '[WAN IP]'
    execute = function(dz, devNil)
        local dzb      = dz.LOG_FORCE
        local getIp    = 'curl -s https://4.ifcfg.me/'
        local tmpFile  = '/home/pi/domoticz/scripts/wanip.txt'
        local actIp    = ''
        local devIp = dz.devices('Wan IP')
        local currIp = devIp.text
        os.execute(getIp..' > '..tmpFile)
        actIp = io.open(tmpFile):read()
        if actIp == nil then actIp = 'Impossibile recuperare IP' end
        if actIp ~= currIp then
            msgTxt = 'Wan IP Cambiato: '..currIp..' ==> '..actIp
            dz.log(msgTxt, dzb)
            dz.notify('Wan IP', msgTxt, dz.PRIORITY_EMERGENCY)
            devIp.updateText(actIp)
            os.execute('rm '..tmpFile)
            dz.log('Nessuna variazione', dzb)
you only have to create a dummy text switch and grab its name (plus, of course replace the italian sentences :P )
Re: WanIP Checker
Posted: Sunday 28 January 2018 21:38
by rlschulz
I attempted to write this for a windows OS and a little less Italian. :-)
So far I built a text switch and am trying to figure out how to get this to run.
Any help would be appreciated.
logging = {
marker = '[WAN IP]'
local tmpFile = 'C:\Program Files (x86)\Domoticz\temp/wanip.txt'
local actIp = ''
if actIp == nil then actIp = 'Unable to retrieve IP' end
msgTxt = 'Wan IP Changed: '..currIp..' ==> '..actIp
dz.log(msgTxt, dzb)
devIp.updateText(actIp)dzb
dz.log('No variations', dzb)
Re: WanIP Checker
Posted: Thursday 31 January 2019 16:14
by dnacid
Change:
to:
local tmpFile = 'C:\\Program Files (x86)\\Domoticz\\temp\\wanip.txt'
I Write my file to a directory without spaces so if the above doesnt work try that.
local tmpFile = 'C:\\Beheer\\Domoticz_Scripts\\wanip.txt'
Re: WanIP Checker
Posted: Thursday 31 January 2019 16:38
by emme
rlschulz wrote: Sunday 28 January 2018 21:38 and a little less Italian. :-)
oops! :oops: :oops: :oops:
:roll: :lol:
Re: WanIP Checker
Posted: Thursday 31 January 2019 20:11
by EddyG
I agree with Egregius, beter use a bashscript.
This bashscript will do the job
#!/bin/bash
fileip='/tmp/WANIP.txt'
filemsg='/tmp/WANIP.msg'
touch $fileip
touch $filemsg
ip=`wget -q -O - http://ipinfo.io/ip`
previp=`cat $fileip`
recipient='[email protected]'
echo $ip > $fileip
if [ "$ip" != "$previp" ]
 then
   echo "Provider changed your ipaddress from: $previp to: $ip" > $filemsg
   mailx -s "IP Change" $recipient < $filemsg
fi
Re: WanIP Checker
Posted: Sunday 03 February 2019 16:32
by rickiewickie
There are of course multiple ways to check your WAN IP, but this is my version.
Perhaps anyone is able to use it..
-- Check WAN IP Script
-- Dummy devices to create
---		Ipaddress as text
--- Run script as time
local device_idx        = 446           -- IDX of the dummy device
local logging 		    = 1				-- when true(1) will print output to log
local sendnotification  = 1             -- send notification when your IP address is changed
--- DO NOT CHANGE ANYTHING BELOW ---
local time = os.date("*t")
function error(msg)
    print("--------------------------------------------------------------------------------------")
	print('-- IP Checker [ERROR] ==>  ' .. msg)
function message(msg)
    print('-- IP Checker ==>  ' .. msg)
function getdevname4idx(deviceIDX)
	for i, v in pairs(otherdevices_idx) do
		if v == deviceIDX then
			return i
	return 0
function validate()
result = true
-- Switches and Devices Error logging.
       if not otherdevices[getdevname4idx(device_idx)] then
          error('Device [' .. getdevname4idx(device_idx) .. '] doesnt exist.')
             result = false
return result
--- Start
if validate() and time.min % 15 == 0 then
   local f = assert(io.popen("curl -s http://www.mijnip.nl/" , 'r'))
   local s = assert(f:read('*a'))
   ip = s:match([[<div id="remoteIPDiv">(.-)</div>]])
   ip = string.gsub(ip, "\n", "") -- remove line breaks
-- Update device if IP is changed
if otherdevices[getdevname4idx(device_idx)] ~= ip then
    commandArray['UpdateDevice'] = device_idx .. '|0|' .. tostring(ip)
    message("IP Address changed to ".. otherdevices_svalues[device_name] )
        -- send notification in case your ip is changed.
        if sendnotification >= 1 then
        error("Notification has been sent.")
	    commandArray['SendNotification']='The WAN ip address is changed to '..ip
if logging >= 1 then
print('Uw externe IP adres is  ==>  '.. ip)
