Due to some requirements I have I've wrote a script to get and eventually update the Wan IP Address.
my provider use not to change the public IP unless the IAD at my home is resetted or remotely upgraded, but since I'm evaluating to remove the ddns and connect just using the externa IP, I was seeking for a way to obtain it.
So I've created a Variable named WanIP_IP and a script that trigger a bash command and do the rest...
here is it
VARNAME = 'WanIP_IP'
GETIP = 'curl -s https://4.ifcfg.me/'
TMPFILE = '/home/pi/domoticz/scripts/wanip.txt'
PTPPREFIX = '>>> [WanIP checker] >>> '
IDLESECS = 21600 -- 6 hours
function timeDiff(dName)
t1 = os.time()
updTime = uservariables_lastupdate[dName]
year = string.sub(updTime, 1, 4)
month = string.sub(updTime, 6, 7)
day = string.sub(updTime, 9, 10)
hour = string.sub(updTime, 12, 13)
minutes = string.sub(updTime, 15, 16)
seconds = string.sub(updTime, 18, 19)
tDiff = os.difftime(t1,t2)
return tDiff
CURRWNIP = uservariables[VARNAME]
IDLETIME = tonumber(timeDiff(VARNAME))
if IDLETIME > IDLESECS then
os.execute(GETIP..' > '..TMPFILE)
wanip = io.open(TMPFILE):read()
if not wanip then
print (PTPPREFIX..'impossibile reperire Wan IP')
if wanip ~= CURRWNIP then
print (PTPPREFIX..'Agiornamento WAN IP: '..wanip)
commandArray['Variable:'..VARNAME] = wanip
os.execute('rm /home/pi/domoticz/scripts/wanip.txt')
than I have a variable script that notify me the change via Telegram and email.
With many thanks to @egregius... I think in bash this can be done in this way:
#!/bin/bash
LASTWANIP =`cat /tmp/lastwanip.txt`
NEWWANIP = `curl -s https://4.ifcfg.me/`
if [[ $LASTWANIP -ne $NEWWANIP ]];then
echo $NEWWANIP > /tmp/lasttemp.txt
DOMOTICZ=`curl -s "http://127.0.0.1:8080/json.htm?type=command¶m=updateuservariable&vname=WanIP_IP&vtype=string&vvalue=$NEWWANIP
fi
ciao
M
