unable to share dummy devices (virtual device DHT22)
Posted: Thursday 24 November 2016 19:46
by PeM1664
Hi all, I'm using new sensors DHT22 and it's working in domoticz's local interface but the device does not appear in my domoticz interface server witch is using domoticz remote server.. do you have any idea?
best regards
Re: problem to share dummy devices
Posted: Thursday 24 November 2016 20:40
by Derik
you have to set the sensor in the usersettings
Posted: Thursday 24 November 2016 23:47
by PeM1664
tks for your answer, yes I did it and the others sensors (ds18b20) works perfectly but the dummy device doesn't want appear... I've tried the method for switch then change the state of the device (here it's value) and restart domoticz remote and domoticz server but nothing...
Re: unable to share dummy devices (virtual device DHT22)
Posted: Sunday 27 November 2016 10:45
by PeM1664
Nobody have this kind of problem? do you need logs or other information?
Posted: Sunday 27 November 2016 11:48
by Derik
in my mind gizmocuz tell me that a dummy share not possible is.. @ the moment...
So if you can implent this, think there a are a lot happy people....
Posted: Sunday 27 November 2016 23:54
by PeM1664
Posted: Tuesday 03 January 2017 20:04
by Veikko
Hi guys!
Is this true that it is unable to share dummy deivces to another Domoticz system?
I made all the setup as described in wiki, but any devices does'nt appear.
Thanks in advance!
Posted: Friday 16 November 2018 19:11
by Teknor
Trying to share an DHT22 temp sensor, connected to a dummy switch. Does not seem to work, all other sensors are easily shared to my main Domoticz installation.
Does anybody know a workaround for this or how to solve the isse?
Posted: Saturday 17 November 2018 10:21
by bewo
Teknor wrote: Friday 16 November 2018 19:11
I do it in a simple way: Set a second virtual device (or the only one) on your "main" domoticz and update it directly. (If it's in the same network.) If you need some help - no problem.
