unable to share dummy devices (virtual device DHT22)
PeM1664
Post by PeM1664 »
Hi all, I'm using new sensors DHT22 and it's working in domoticz's local interface but the device does not appear in my domoticz interface server witch is using domoticz remote server.. do you have any idea?
best regards :)
Derik
Re: problem to share dummy devices
Post by Derik »
you have to set the sensor in the usersettings
PeM1664
Post by PeM1664 »
tks for your answer, yes I did it and the others sensors (ds18b20) works perfectly but the dummy device doesn't want appear... I've tried the method for switch then change the state of the device (here it's value) and restart domoticz remote and domoticz server but nothing...
PeM1664
Re: unable to share dummy devices (virtual device DHT22)
Post by PeM1664 »
Nobody have this kind of problem? do you need logs or other information?
Derik
Post by Derik »
in my mind gizmocuz tell me that a dummy share not possible is.. @ the moment...
So if you can implent this, think there a are a lot happy people....
PeM1664
Post by PeM1664 »
Veikko
Domoticz version: V3.5877
Post by Veikko »
Hi guys!
Is this true that it is unable to share dummy deivces to another Domoticz system?
I made all the setup as described in wiki, but any devices does'nt appear.
Thanks in advance!
Dr. Lanning: "One day they'll have secrets, one day they'll have dreams..."
Teknor
Domoticz version: 3.48
Post by Teknor »
Trying to share an DHT22 temp sensor, connected to a dummy switch. Does not seem to work, all other sensors are easily shared to my main Domoticz installation.
Does anybody know a workaround for this or how to solve the isse?
Raspberry Pi 3 | EasyESP NodeMCU v3 | RFXTRX433e | Mysensors NRF24L01 | MotionEYE | PikrellCam
bewo
Domoticz version: 2021.1
Post by bewo »
Teknor wrote: Friday 16 November 2018 19:11 Trying to share an DHT22 temp sensor, connected to a dummy switch. Does not seem to work, all other sensors are easily shared to my main Domoticz installation.
I do it in a simple way: Set a second virtual device (or the only one) on your "main" domoticz and update it directly. (If it's in the same network.) If you need some help - no problem. ;)
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
