struggle script (including json rule) >> update virtual sensor
Posted: Wednesday 23 November 2016 17:18
by Jan Jansen
I connected an AM2302 (Temp/Hum sensor) on my rpi (running Domoticz). I first created a virtual sensor (idx 109). Then I tried viewtopic.php?f=12&t=9531#p79641, crontab 5 minutes.
#!/bin/sh
# Domoticz server
SERVER="127.0.0.1:8080"
# DHT IDX
DHTIDX="109"
# DHTPIN
DHTPIN="17"
sleep 5
sudo nice -20 python /home/pi/Adafruit_Python_DHT/examples/AdafruitDHT.py 2302 $DHTPIN > /var/tmp/temp.txt
#TEMP=$(cat /var/tmp/temp.txt | grep "Temp" | awk '{ print $3 }')
#TEMP=$(cat /var/tmp/temp.txt | grep "Temp")
TEMP=$(awk ' /Temp/ {print substr ($0,6,4)}' /var/tmp/temp.txt)
#HUM=$(awk ' /Hudmidity/ {print substr ($0,0)}' /var/tmp/temp.txt)
#HUM=$(awk ' /Humidity/ {print 1$}' /var/tmp/temp.txt)
HUM=$(awk ' /Humidity/ {print substr ($0,22,4)}' /var/tmp/temp.txt)
echo $TEMP
echo $HUM
# Send data
curl -s -i -H "Accept: application/json" "http://$SERVER/json.htm?type=command&c=getauth&param=udevice&idx=$DHTIDX&nvalue=0&svalue=$TEMP;$HUM;2"
TEMP=""
HUM=""
In temp.txt I see every 5 minutes an update on temp and hum. I therefore think that the first part of the script works, but there is no update of the virtual sensor (color red). I took a look in the Wiki (json) but I found no solution.
Then I tried the following code based on: https://easydomoticz.com/raspberry-et-dht11/ .
#!/bin/bash
# Domoticz server
SERVER="192.168.0.6:8080"
# DHT IDX
DHTIDX="109"
#DHTPIN
DHTPIN="17"
TMPFILE="/var/tmp/dhtsensor1.txt"
cpt=0
while [ $cpt -lt 6 ]
do
TEMP=""
sleep 5
sudo nice -20 python /home/pi/domoticz/scripts/Adafruit_Python_DHT/examples/AdafruitDHT.py 2302 $DHTPIN > $TMPFILE
TEMP=$(cat $TMPFILE|grep Temp |awk '{print $3}')
if [ $TEMP ]
then
HUM=$(cat $ $TMPFILE |grep Temp |awk '{print $7}')
#echo $TEMP
#echo $HUM
# Send data
curl -s -i -H  "Accept: application/json"  "http://$SERVER/json.htm?type=command&param=udevice&idx=$DHTIDX&nvalue=0&svalue=$TEMP;$HUM;2"
TEMP=""
HUM=""
rm $TMPFILE
exit 0
fi
#echo $cpt
cpt=$(($cpt+1))
done
exit 1
In dhtsensor1.txt I see every 5 minutes an update on temp and hum. But again no update on the virtual sensor.
I'm stuck, I hope someone can help.
Thank you in advance!
Jan
Re: struggle script (including json rule) >> update virtual sensor
Posted: Wednesday 23 November 2016 20:57
by stlaha2007
Hi Jan,
Can you post the contents of the files in /var/temp and whats on your console when you run it yourself?
I'm doing simular things... And i think the wrong or no value at all for hum is generated...
And also try curl from commandline, to test its response. Perhaps you just getting ERR by feeding through JSON with nothing.
Posted: Thursday 24 November 2016 16:57
by Jan Jansen
Hello stlah,
First thanks for your quick reply. Before I read your post i have tried next http://blog.briankmarsh.com/domoticz/ .
#!/bin/bash
# Domoticz server
SERVER="localhost:8080"
# IDX DHT
# The number of the IDX in the list of peripherals
DHTIDX="109"
#DHTPIN
# THE GPIO or connects DHT11
DHTPIN="17"
# If you have a DHT22 change further down the line Adafruit_DHT 11 by 22 Adafruit_DHT
# TMPFILE: path for temporary file in place to avoid the RAMDRIVE
# Scriptures on the SD card
# Otherwise be written way or the file containing the temperature
# /tmp/temper.txt Is a good choice if not installed RAMDRIVE
# Www.easydomoticz.com visit to learn all
# Modified patrick from 03/08/15 to question 5 times max
cpt=0
do
TEMP=""
sleep 5
sudo nice -20 /home/pi/domoticz/scripts/Adafruit_Python_DHT/examples/AdafruitDHT.py 2302 $DHTPIN > $TMPFILE
TEMP=$(cat $TMPFILE|grep Temp |awk '{print $1}')
if [ $TEMP ]
then
TEMP=$(cat $TMPFILE|grep Temp |awk '{print $1}' |sed -r 's/^.*=//' |  sed -r 's/\*//')
HUM=$(cat $TMPFILE |grep Temp |awk '{print $2}' | sed -r 's/^.*=//' | sed -r 's/\%//')
if [ $(echo "$HUM < 30" |bc) ]
then
COMFORT=2
elif [ $(echo "$HUM < 40" |bc) ]
then
COMFORT=0
elif [ $(echo "$HUM < 60" |bc) ]
then
COMFORT=1
COMFORT=3
fi
echo "TEMP: $TEMP"
echo "HUM: $HUM"
echo "COMFORT: $COMFORT"
# send data
curl -s -i -H "Accept: application/json" "http://$SERVER/json.htm?type=command&param=udevice&idx=$DHTIDX&nvalue=0&svalue=$TEMP;$HUM;$COMFORT"
TEMP=""
HUM=""
#rm $TMPFILE
exit 0
fi
echo "CPT: $cpt"
cpt=$(($cpt+1))
done
exit 1
Running this one shows:
I hope you know a solution.
Thanks in advance!
Jan
Posted: Monday 28 November 2016 19:59
by Jan Jansen
After reading viewtopic.php?f=28&t=14383&p=105237&hil ... ed#p105237 I found a solution.
Jan
