Import external data as device
Donald
Post by Donald »
Just started with Domoticz using some Zwave devices and wired thermometers, but I want more :)
I already use a RaspberryPi with "123solar" and "Metern" for my solar pannels and P1 energy meter and want to keep on using this system since it contains a 3-4 year old database.
Is it possible to import the values of these energy meters? Can I, for example, make a dummy meter with "value gas meter = cat /var/log/gas.txt" as device?
Grtz Don
Egregius
Domoticz version: v2024.7
Re: Import external data as device
Post by Egregius »
Sure, what data is in the txt file?
As example, I read a CSV file created by SBFSpot and use the response from domoticz as a service online check:
#!/bin/bash
while :
do
	SECOND=$(date +%S)
	if [ $SECOND -eq 0 ]
	then
		H=$(date +%H)
		if (( 8 <= 10#$H && 10#$H < 23 )); then
			string=$(tail -1 $(/bin/ls -1t /volume1/files/temp/SBFSPOT/Zon-Spot*.csv | /bin/sed q))
			var=$(echo $string | awk -F";" '{print $1,$2,$3,$4,$5,$6,$7,$8,$9}')
			set -- $var
			oost=$8
			west=$9
			var=$(echo $oost | awk -F"," '{print $1}')
			set -- $var
			oostint=$1
			var=$(echo $west | awk -F"," '{print $1}')
			set -- $var
			westint=$1
			sum=$((oostint + westint))
			sum=0
		fi
		DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8084/json.htm?type=command&param=udevice&idx=6&nvalue=0&svalue=$sum"`
		STATUS=`echo $DOMOTICZ | jq -r '.status'`
		if [ "$STATUS" == "OK" ] ; then
			#curl -s --connect-timeout 60 --max-time 60 "http://127.0.0.1/secure/phones.php"
			exit
			sleep 5
			STATUS2=`echo $DOMOTICZ | jq -r '.status'`
			if [ "$STATUS2" == "OK" ] ; then
				exit
				sleep 5
				STATUS3=`echo $DOMOTICZ | jq -r '.status'`
				if [ "$STATUS3" == "OK" ] ; then
					exit
					curl -s --connect-timeout 2 --max-time 5 --data-urlencode "text=Domoticz Bad - Restarting" --data "silent=false" http://127.0.0.1/secure/telegram.php
					NOW=$(date +"%Y-%m-%d_%H%M%S")
					cp /volume1/appstore/domoticz/var/domoticz.log /volume1/files/temp/domoticz-$NOW.txt
					sudo /var/packages/domoticz/scripts/start-stop-status stop
					sleep 8
					sudo kill $(sudo netstat -anp | awk '/ LISTEN / {if($4 ~ ":8084$") { gsub("/.*","",$7); print $7; exit } }')
					sleep 8
					sudo /var/packages/domoticz/scripts/start-stop-status start
				fi
			fi
		fi
	fi
	sleep 0.8
done
The CSV looks like this:
sep=;
Version CSV1|Tool SBFspot3.3.1 (Linux)|Linebreaks CR/LF|Delimiter semicolon|Decimalpoint comma|Precision 3
;;;;Watt;Watt;Amp;Amp;Volt;Volt;Watt;Watt;Watt;Amp;Amp;Amp;Volt;Volt;Volt;Watt;Watt;%;kWh;kWh;Hz;Hours;Hours;%;Status;Status;degC
dd.MM.yyyy HH:mm;DeviceName;DeviceType;Serial;Pdc1;Pdc2;Idc1;Idc2;Udc1;Udc2;Pac1;Pac2;Pac3;Iac1;Iac2;Iac3;Uac1;Uac2;Uac3;PdcTot;PacTot;Efficiency;EToday;ETotal;Frequency;OperatingTime;FeedInTime;BT_Signal;Condition;GridRelay;Temperature
22.11.2016 08:36;SN: 2100035823;SB 5000TL-20;2100035823;24,000;7,000;0,123;0,037;202,810;215,850;22,000;0,000;0,000;0,098;0,000;0,000;235,920;0,000;0,000;31,000;22,000;0,000;0,000;37574,581;50,000;33066,151;32189,152;72,941;Ok;Closed;23,570
22.11.2016 08:37;SN: 2100035823;SB 5000TL-20;2100035823;26,000;8,000;0,129;0,038;202,830;215,830;25,000;0,000;0,000;0,109;0,000;0,000;236,150;0,000;0,000;34,000;26,000;0,000;0,000;37574,581;50,000;33066,168;32189,168;72,549;Ok;Closed;23,570
22.11.2016 08:38;SN: 2100035823;SB 5000TL-20;2100035823;27,000;8,000;0,135;0,039;202,830;215,850;27,000;0,000;0,000;0,117;0,000;0,000;235,730;0,000;0,000;35,000;27,000;0,000;0,001;37574,582;49,990;33066,184;32189,185;74,118;Ok;Closed;23,570
22.11.2016 08:39;SN: 2100035823;SB 5000TL-20;2100035823;28,000;8,000;0,142;0,042;202,830;215,850;29,000;0,000;0,000;0,126;0,000;0,000;236,090;0,000;0,000;36,000;29,000;0,000;0,001;37574,582;50,000;33066,201;32189,202;72,157;Ok;Closed;23,570
22.11.2016 08:40;SN: 2100035823;SB 5000TL-20;2100035823;30,000;9,000;0,153;0,048;202,830;215,850;31,000;0,000;0,000;0,133;0,000;0,000;236,190;0,000;0,000;39,000;31,000;0,000;0,002;37574,583;50,000;33066,218;32189,218;72,549;Ok;Closed;23,780
22.11.2016 08:41;SN: 2100035823;SB 5000TL-20;2100035823;31,000;10,000;0,159;0,050;202,830;215,850;32,000;0,000;0,000;0,141;0,000;0,000;236,440;0,000;0,000;41,000;32,000;0,000;0,002;37574,583;50,000;33066,234;32189,235;73,725;Ok;Closed;23,780
22.11.2016 08:42;SN: 2100035823;SB 5000TL-20;2100035823;32,000;10,000;0,163;0,048;202,830;215,850;35,000;0,000;0,000;0,150;0,000;0,000;236,250;0,000;0,000;42,000;35,000;0,000;0,003;37574,584;49,980;33066,251;32189,252;73,333;Ok;Closed;23,780
22.11.2016 08:43;SN: 2100035823;SB 5000TL-20;2100035823;34,000;10,000;0,171;0,053;202,830;215,850;36,000;0,000;0,000;0,155;0,000;0,000;236,240;0,000;0,000;44,000;36,000;0,000;0,003;37574,584;49,990;33066,268;32189,268;74,118;Ok;Closed;23,780
22.11.2016 08:44;SN: 2100035823;SB 5000TL-20;2100035823;35,000;10,000;0,175;0,052;202,810;215,850;39,000;0,000;0,000;0,166;0,000;0,000;236,240;0,000;0,000;45,000;39,000;0,000;0,004;37574,585;49,980;33066,284;32189,285;73,333;Ok;Closed;23,780
Donald
Post by Donald »
Thnx, I am not a programmer. It will take some time to have it functional I suppose.
pj-r
Domoticz version: V3.8650
Post by pj-r »
@Egregius: your script wont work in this case. Donald needs to "upload" all the historical data he has for 3-4 years to domoticz.
Domoticz JSON api supports only sending of current value no historical value..
Yes its possible. And no its not easy task. It has to be done by calculating daily values and uploading the data directly to domoticz.db. Its sqlite database. Check out tables: DeviceStatus, Multimeter and Multimeter_Calendar
And this code: https://github.com/domoticz/domoticz/bl ... .cpp#L4515
I think there is no ready made functionality for this. Some one could correct if I'm wrong.
Egregius
Post by Egregius »
I missed the part for the history :P
Script is only for actual data.
