I just started using Domoticz on an RPI3 which already has an extensive sensor network connected through 1-Wire (I2C->1-Wire bridges + OWFS) as well as sensors connected directly to the I2C bus..
These sensors consist of barometric sensors, light/uv level, humidity, gas sensors connected to I2C ADC's etc.. I can read these individually through some scripts but would like to integrate this into domoticz.
Does Domoticz support the use of I2C sensors directly ? or should I setup scripts for each of these sensors ?
Support for I2C based sensors connected to RPI I2C interface?
