Home Easy HE801S and pairing Topic is solved
Sappien
Post by Sappien »
I've got a Home Easy power on/off socket HE801S but I don't get it paired in Domoticz..
When I pair it with RFXmngr it works
but no luck with Domoticz
I've tried AC and HomeEasy..
Packettype    = Lighting2
subtype       = AC
Sequence nbr  = 4
ID            = 00028E8 decimal:10472
Unit          = 2
Command       = On
Signal level  = 7  -64dBm
subtype       = HomeEasy EU
Sequence nbr  = 5
ID            = 00000C0 decimal:192
Unit          = 2
Command       = On
Signal level  = 5  -80dBm
What do I forget? :geek:
Sappien
Re: Home Easy HE801S and pairing
Post by Sappien »
Never mind... I've tested RFXmngr at a range of 1 meter... I've was trying to pair it on the first floor (5 meter).. but thats to far for HomeEasy... :shock:
My old KAKU/COCU had no issues with the second floor (2 concrete walls)
Time to order more ESP8266 with relays ;)
