Virtual Sensor test
mbursteing
Virtual Sensor test
Post by mbursteing »
I'm trying to test mqtt protocol with Domoticz. For that I'm using a BeagleBone Black with mosquitto that takes a value from a existing sensor in Domoticz with JSON, and send this value over MQTT to Domoticz to a virtual sensor. the problem is that I'm not getting any value on the virtual sensor. I'm using a shell script
#!/bin/bash
while true
do
value=$(python -c 'import sensorValue; print sensorValue.sensor_value(8)')
mosquitto_pub -h 192.168.1.13 -m '{ "idx" : 13, "nvalue" : 0, "svalue" : "$value" }' -t 'domoticz/$
sleep 1
done
This code is running well cuz Domoticz virtual sensor updates every minute, but with no value. Thanks.
Regards,
Marcelo
ps: sensorValue is a function that takes the value of an specific sensor on Domoticz. In this case idx=8
mbursteing
Re: Virtual Sensor test
Whats' the differenco of usin ' ' and using " ", cuz when I test the mqtt message sent using anoter suscriber I can see that the received message is good, I can see the sensor value, but why Domoticz can't see it?
mbursteing
Any help?
when I use this command
mosquitto_pub -h 192.168.1.13 -m "{ "idx" : 13, "nvalue" : 0, "svalue" : "$value" }" -t "domoticz/in"
I can't change the sensor value. But, when I use single quotes like this:
mosquitto_pub -h 192.168.1.13 -m '{ "idx" : 13, "nvalue" : 0, "svalue" : "$value" }' -t "domoticz/in"
I can. the problem is that it doesn't get any value cuz the single quotes allows only strings
fets
Domoticz version: 2.2969
Post by fets »
Inside single quotes, variables are not interpreted. So you need to use double and bachslash each double quote as this :
mosquitto_pub -h 192.168.1.13 -m "{ \"idx\" : 13, \"nvalue\" : 0, "svalue\" : \"$value\" }" -t "domoticz/in"
