Way to enable/disable whole switch schedule...
lost
Post by lost »
I've found no easy way to enable/disable whole shedule in a switch:
-There is the possibility to switch between 2 schedules (normal+vacations), this may help but does not really does the job (maybe done by having more shedules & mapping a selector virtual switch on them, indeed).
-Through the json api, there is a way to do this. But as every line in a schedule looks to be triggered by a timer (each with it's own timer idx) & json api uses timer idx this is not easy to invalidate all a switch schedule this way.
-Reading forum, I tried to use one sideway that alters to domoticz db directly: Looks successfull when looking at the enable statuses but sometimes, all schedules are set back to on! Probably it's not very sane to alter domoticz db while running: This may be cached somewere and previous enable statuses set back. Yesterday, I had to replace windows & used the virtual switch triggered scripts that invalidate all floor heaters plannings + sets them to off... but they restarted later because switches schedules were re-enabled.
So my question is: Is there a way to do this I may have missed (quite new to Domoticz)? If not, could it make it's way in the feature list for next version?
BR
dressie
Domoticz version: V2020.2
Re: Way to enable/disable whole switch schedule...
Post by dressie »
*bump*
Did we ever find a solution to this?
dressie wrote: Sunday 05 May 2019 9:20 *bump*
I use different timerplans to do just this. To give an idea how this can work..:
Below dzVents script change the timerplans based on the content of a domoticz text-device. This ensure that we are not waked too early by blinds going up when we do not have to work :D
--[[ SetTimerplan.lua
    on      =   {   variables = { 'GCal*' } },
    logging =   {   level = domoticz.LOG_ERROR,                                      -- DEBUG, ERROR or INFO
                    marker = "setTimerPlan" },
    execute = function(dz)
        dz.log ("Calender XXXX text: " .. dz.devices('Calender XXXX Text').text,dz.LOG_DEBUG)
        local function setTimerplan(timerPlan)
            local jsonString = dz.settings['Domoticz url'] ..  "/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=" .. tostring(timerPlan)
            dz.openURL(jsonString)
            dz.variables('TimerPlan').set(timerPlan)
            newTimerPlan = timerPlan
        local function inString(text, searchString)
            if string.find(string.lower( text),searchString ) ~= nil then
                return true
                return false
        local XXXX         =  dz.devices('Calender XXXX Text').text -- Text from Google calendar
        local ZZZZ    =  dz.devices('Calender XXXX en YYYY Text').text
        local timerPlan     =  dz.variables('TimerPlan').value
        local newTimerPlan  =  timerPlan
        if dz.time.matchesRule('at 22:00-02:00') then
            if (inString ( XXXX,"erken" ) or inString ( XXXX,"ursus" )) then
                setTimerplan(0)                                          -- XXXX at work so default TimerPlan
            elseif (inString ( ZZZZ,"holiday" ) or inString ( ZZZZ,"vakantie" )) and timerPlan ~= 1 then
                setTimerplan(1)        -- It is a Holiday
            elseif timerPlan ~= 2 then
                setTimerplan(2)          -- No Holiday but no working day either (including weekends)
        dz.log ("timerPlan:                 " .. newTimerPlan,dz.LOG_DEBUG)
        dz.log ("calendar XXXX:            " .. XXXX,dz.LOG_DEBUG)
        dz.log ("calendar XXXX en YYYY:    " .. ZZZZ,dz.LOG_DEBUG)
gizmocuz
Post by gizmocuz »
I suggest the following:
- Add a new Field in the DeviceStatus table, ScheduleActive (default true)
- In the "Edit Timer" GUI code, add a checkbox "Active" and use this to enable/disable all the timers of that device/switch
- When changing this checkbox, reload the schedules
Of course some code need to be adjusted as well to only load the timers if they are enabled for this device
And then of course a pull request on github would be appreciated
