zwave-how to control wall-plug with domoticz and physical switch
Posted: Sunday 06 November 2016 23:48
by Lectere
Hi, I'm new to zwave and Domoticz, and I have a conceptual question;
I have a wall-plug, and I can associate it with Domoticz (via USB zwave stick), OR with the nodon switch.
I cannot associate the two to operate the same wall-plug. I'd like to be able to control the wall-plug from domoticz via the USB zwave stick and using the nodon switch.
What the best way to achieve this? In zwave terms, what's this called?
And, oh yea, I'd like to be able to control the switch also when Domoticz is down.
Thnx in advance!
Re: zwave-how to control wall-plug with domoticz and physical switch
Posted: Monday 07 November 2016 8:16
by Egregius
Include both in Domoticz. Set the nodon as a slave device of the plug and it'll trigger it automagically.
Posted: Monday 07 November 2016 8:33
by Lectere
Thanks for the advice, ill try this when I get home, in general, how do you call this process?
Posted: Monday 07 November 2016 8:45
by emme
Lectere wrote:, I'd like to be able to control the switch also when Domoticz is down.
if both device are ZWave, I think you can associate master/slave in the zWave Device control panel (under Hardware)
if domoticz is down the zWave network can still operate, but you need to have the zWave stick poeered
Posted: Wednesday 09 November 2016 21:49
by bjacobse
I did a Blockly script, to let switch1 control switch3. they are both zwave switches, Fibaro relay something.
Posted: Thursday 10 November 2016 13:17
by Lectere
Thanks very much for all your responses, but I really need a solution that is also working when my Pi+Controller is down.
@Egregius do I need to put the NodOn in gateway mode?
Posted: Saturday 19 November 2016 23:23
by qbic2007
Hi Lectere
You can do this easily by groups, at least if your modules support this.
I have the fibaro double switch and wall plug, sw2 triggers on/off the wall plug and it does this without the need for a controller (after configuration obvious)
slaapkamer = double switch > Group 2 (=sw2 for this device), add device '3'
sterren = wall plug
