converting Variable into table
emme
Domoticz version: latest
Post by emme »
I have few time scripts that are supposed to run several times a day, at a specific time.
Actually the time is trigged inseide the LUA code, but I was looking for a smarter way to drive it...
So I was thinking to use a table inside a variable... but here I come with a problem using such information in LUA:
first: My script is supposed to run at hour 7, 11,14,17,21 (munite is fixed at 00), so I create a string global variable named RunOnTime with values 7, 11, 14, 17, 21
in LUA I don't know how to convert it into an array:
tstArray = { uservariables['RunOnTime'] }
seems not working while
tstArray = {7, 11, 14, 17, 21}
works correctly
how do I convert strings into tables?! :(
thanks
ciao
M
"We always done this way"
emme
Re: converting Variable into table
Post by emme »
uh... found a possible solution... but I would like it would be a better and faster way....
got some code from lua-users.org
function fromCSV (s)
  s = s .. ','        -- ending comma
  local t = {}        -- table to collect fields
  local fieldstart = 1
  repeat
    -- next field is quoted? (start with `"'?)
    if string.find(s, '^"', fieldstart) then
      local a, c
      local i  = fieldstart
      repeat
        -- find closing quote
        a, i, c = string.find(s, '"("?)', i+1)
      until c ~= '"'    -- quote not followed by quote?
      if not i then error('unmatched "') end
      local f = string.sub(s, fieldstart+1, i-1)
      table.insert(t, (string.gsub(f, '""', '"')))
      fieldstart = string.find(s, ',', i) + 1
    else                -- unquoted; find next comma
      local nexti = string.find(s, ',', fieldstart)
      table.insert(t, string.sub(s, fieldstart, nexti-1))
      fieldstart = nexti + 1
  until fieldstart > string.len(s)
  return t
