P1 Smart meter USB does not save 115200 baud rate correct
bart59
Post by bart59 »
(Raspberry PI 3 - version v3.5849 (beta) also same with the stable version
In the "setup" screen for the "P1 Smart Meter" you can select the baud rate (9600 or 115200). I see 3 problems:
1. In the web interface the setting for 115200 is not saved. When returning to this page the setting falls back to 9600
2. When setting the baud rate (either 9600 or 115200), the log shows the message "Error: Webserver: File '/setp1usbtype.webem': No such file or directory (2)"
3. The USB port does not seem to be set at all. My meter sends data at 115200 and all device values stay at 0
I can force the USB port to the right baud rate as follows:
- from a separate terminal window I first installed minicom:
sudo apt-get minicom
- then I can hook into the same USB port where the P1 cable is attached (USB0) with:
minicom -b 115200 -o -D /dev/ttyUSB0
- now I see in my terminal window the smart meter data coming in --> at the same time Domoticz sees the same data and the smart meter data is also visible in the device graph
- when I terminate minicom, the data towards Domoticz also stops
I think this must be a bug in some of the core USB functions in Domoticz. Any other suggestions?
Bart
bart59
Re: P1 Smart meter USB does not save 115200 baud rate correct
Post by bart59 »
I am no longer able to reproduce the problem. It seems to work fine now. I do have another problem that may be related: I have 2 USB devices plugged into my Raspberry: P1 cable and RFXcom tranceiver. With each reboot of the raspberry the allocation of ttyUSB0 and ttyUSB1 is kind of random. This means that if Domoticz is configured to use ttyUSB0 for the P1 cable, the device may show up at ttyUSB1 after the next reboot. This means the P1 connection no longer works. I fixed this using the following procedure:
(see http://unix.stackexchange.com/questions ... tatic-name for more info)
from a terminal window:
1. find out what's on ttyUSB:
pi@raspberrypi:~ $ dmesg | grep ttyUSB
[    4.074363] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
[    4.075590] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB1
Take not of the node numbers: 1-1.2 and 1-1.3
2. list all attributes of the devices (in my case USB0 and USB1):
pi@raspberrypi:~ $ udevadm info --name=/dev/ttyUSB0 --attribute-walk
pi@raspberrypi:~ $ udevadm info --name=/dev/ttyUSB1 --attribute-walk
  looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2':
    KERNELS=="1-1.2"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{bDeviceSubClass}=="00"
    ATTRS{bDeviceProtocol}=="00"
    ATTRS{devpath}=="1.2"
    ATTRS{idVendor}=="0403"
    ATTRS{speed}=="12"
    ATTRS{bNumInterfaces}==" 1"
    ATTRS{bConfigurationValue}=="1"
    ATTRS{bMaxPacketSize0}=="8"
    ATTRS{busnum}=="1"
    ATTRS{devnum}=="4"
    ATTRS{configuration}==""
    ATTRS{bMaxPower}=="90mA"
    ATTRS{authorized}=="1"
    ATTRS{bmAttributes}=="a0"
    ATTRS{bNumConfigurations}=="1"
    ATTRS{maxchild}=="0"
    ATTRS{bcdDevice}=="0600"
    ATTRS{avoid_reset_quirk}=="0"
    ATTRS{quirks}=="0x0"
    ATTRS{serial}=="A1LPXWF"
    ATTRS{version}==" 2.00"
    ATTRS{urbnum}=="179474001"
    ATTRS{ltm_capable}=="no"
    ATTRS{manufacturer}=="RFXCOM"
    ATTRS{removable}=="removable"
    ATTRS{idProduct}=="6001"
    ATTRS{bDeviceClass}=="00"
    ATTRS{product}=="RFXtrx433"
Look at tree leaf matching the node name from the prior step. I my case ..../usb1/1-1/1-1.3 en ..../usb1/1-1/1-1.2
The RFXCON and P1 both had the same idVendor (0403) and idProduct (6001), but they had different serial numbers. That part matters, because we are now going to create a new USB device linked to that specific serial number
3. Create a file /etc/udev/rules.d/10-usb-serial.rules with rules for all USB devices in it:
pi@raspberrypi:~ $ sudo nano /etc/udev/rules.d/10-usb-serial.rules
type the following in the editor and then save the file (ctrl-o) and (ctrl-x):
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTR{serial}=="P11234567",  SYMLINK+="ttyUSB_P1"
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTR{serial}=="RFX1234567",  SYMLINK+="ttyUSB_RFX"
Note: the serial numbers, idVendor and idProduct shown need to be replaced by your ids
4. Load the new rule:
pi@raspberrypi:~ $ sudo udevadm trigger
5. Verify what happened:
pi@raspberrypi:~ $ ls -l /dev/ttyUSB*
crw-rw---- 1 root dialout 188, 0 Nov 11 10:29 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 Nov 11 10:00 /dev/ttyUSB1
lrwxrwxrwx 1 root root         7 Nov 11 10:00 /dev/ttyUSB_P1 -> ttyUSB1
lrwxrwxrwx 1 root root         7 Nov 11 10:00 /dev/ttyUSB_RFX1 -> ttyUSB0
As you see we still have the existing USB0 and USB1 devices, but also have 2 symbolic links to devices that are match the right hardware. These symbolic links will be created at each reboot or when the USB device is plugged into an USB port.
6. Now in Domoticz below the Hardware menu change the device for the P1 cable to ttyUSB_P1 and the one for RFXCOM to ttyUSB_RFX1
stlaha2007
Post by stlaha2007 »
Nice, seen at wiki mentioned 'persistant usb devices' however couldn't recall the serial as destinction :-)
Sent from my K00C using Tapatalk
