Stopping blinds movement
PatrickM
Post by PatrickM »
I'd like to control my Blinds Percentage device with a remote control, but using the script api, as far as I can tell, only allows to open or close it fully. What would be the best approach to stop it halfway? Similar questions have been asked before here and here and apparently some remotes (somfy, z-wave remotes) can do it directly, circumventing domoticz. I'm using a cheap X10 RF remote (with RFLink).
The hardware is Fibaro FGRM-222. When I repeat an open or close command, unfortunately it is ignored or movement is reversed instead of stopped. The local switch does stop movement: if it is moving when you push either open or close it stops first, and you need to push again to resume or reverse movement. I'd like my remote control to work in the same way.
Probably I can get it to work by calling into ozwcp directly from a script (like this). I can use the 'native' open/close or inc/dec commands to stop movement, instead of the on/off commands exposed by domoticz. But I'd have to find a way to determine in my script if the screen is currently moving, perhaps by checking power usage? A more crude but hardware independent approach could be to mess around with timers, using periodic increments to keep the blinds moving, until a new signal is received that stops it but obviously this is inconvenient and probably not very precise/robust (cpu intensive).
Is there some kind of hidden feature, or future plans to achieve this in an elegant, reliable way?
Stuntteam
Re: Stopping blinds movement
Post by Stuntteam »
We are looking at a solution for button sequences at RFLink's side of things.
It will take a bit of time to work things out though.
PatrickM
Post by PatrickM »
I've settled for the (dzVents) script below, which works reasonably well. There's some delay but most of it is caused by RFLink not receiving repeated button presses. I looks like it's 'deaf' for at least 1 sec. after receiving a button press. If there's any way to improve this all tips are welcome :)
    active = true,
        "$Remote 1", "$Remote 2", "$Remote 3"
    execute = function(domoticz, button)
        local screen; -- zipscreen device
        local power; -- current power usage
        local ozwIdx; -- zipscreen index in ozw
        local threshold = 10;
        --domoticz.log("Button pressed (" .. button.name .. " -> " .. button.state .. ")");
        if (button.name == "$Remote 1") then
            screen = domoticz.devices['Zipscreen L'];
            power = domoticz.devices['Zipscreen L Power'].utility;
            ozwIdx = "5";
        elseif (button.name == "$Remote 2") then
            screen = domoticz.devices['Zipscreen M'];
            power = domoticz.devices['Zipscreen M Power'].utility;
            ozwIdx = "7";
        elseif (button.name == "$Remote 3") then
            screen = domoticz.devices['Zipscreen R'];
            power = domoticz.devices['Zipscreen R Power'].utility;
            ozwIdx = "2";
        if (screen and power) then
            if (power > threshold) then
                domoticz.log(screen.name .. " -> Stop (" .. power .. "W / " .. screen.state .. ")");
                local post = ozwIdx .. "-SWITCH MULTILEVEL-user-button-1-7=false"
                local url = "http://" .. domoticz.settings['Domoticz ip']
                            .. ":" .. domoticz.settings['Domoticz port']
                            .. "/ozwcp/buttonpost.html";
                local cmd = "curl '" .. url .. "' --data '" .. post .. "'";
                --domoticz.log("Execute: " .. cmd);
                os.execute(cmd);
                if (button.state == "On") then
                    domoticz.log(screen.name .. " -> Close (" .. power .. "W / " .. screen.state .. ")");
                    screen.switchOff();
                    domoticz.log(screen.name .. " -> Open (" .. power .. "W / " .. screen.state .. ")");
                    screen.switchOn();
            domoticz.log("Failed to lookup screen (" .. tostring(screen) .. ") \z
                          and/or power usage (" .. tostring(power) .. ")");
        domoticz.log("Fini");
kolargol22
Post by kolargol22 »
Stuntteam wrote:We are looking at a solution for button sequences at RFLink's side of things.
+1 i use Brel Motors and on my DC306 remote i have "stop" button but on domoticz + rflink i am able only to fully open or close blinds. It would be nice if i can control when blind stop (perfectly if i can set % on that...)
Stuntteam
Post by Stuntteam »
Why that? Didn't you select Venetian blinds in Domoticz? That has a stop button..
Or is stop not working?
kolargol22
Venetian indeed there are but they do not work with homebridge... (HomeKis show it as unrecognized device)
wmmudde
Post by wmmudde »
Did you Got this working on HomeKit now ?
