In my system (DOMOTICZ on RASPBERRY) I have a PIR sensor in a hallway.
During the night, from bedroom you must to pass in this hallway (where I have a Fibaro Motion Sensor) to go to the bathroom (where there is a FIBARO DIMMER) .
In LUA I write a simple script that SET LEVEL 20% to batroom FOR 2 MINUTES during nighttime (so your eyes are safe!) .
All is ok, but only when we are sleeping!
Because, if someone go to bathroom for a shower in the evening, in example, the light turn off after 2 minutes (it must to pass through the hallway).
I would like to understand if there is the possibility to "cancel" the LUA command ("set 20 for 2") if I press the BATHROOM SWITCH (linked to S1 of the DIMMER).
I read all the SMART LUA and SMART PIR sections, but no idea there to cancel (or what else!) the first command set from the LUA SCRIPT.
-- NightLightBathroom.lua
-- Bathroom Dimmer name: Level Luce Bagno
-- Hallway PIR SENSOR: Sensore Disimpegno
local DeviceDimmer = 'Level Luce Bagno'
local DeviceSensore = 'Sensore Disimpegno'
local SetLevel = 'Off'
if (devicechanged[DeviceSensore]) then
if (timeofday['Nighttime']) and (otherdevices[DeviceDimmer]=="Off") then
SetLevel = 'Set Level 20 FOR 2';
commandArray[DeviceDimmer] = SetLevel
Thank you a lot in advance!
If you need some other informations to help me, please ask me.
Giulio
