Dummy Thermostat
Posted: Thursday 27 October 2016 14:30
by JacquesMulders
Is it possible to create a dummy thermostat just like the evohome system has, with a thermostat setpoint and the actual temperature. now is it only possible to create a dumme thermostat setpoint.
i've tryed it to create a virtual thermostat using this url
/json.htm?type=createvirtualsensor&idx=894&sensorname=Testthermostaat&sensortype=70
(in the database the evohome devices has type 70)
Re: Dummy Thermostat
Posted: Thursday 27 October 2016 19:19
by JacquesMulders
found out that the url was wrong... correct url is :
/json.htm?type=createevohomesensor&idx=<IDX OF DUMMY HARDWARE>&sensortype=70
maybe it can be implemented in de dummy hardware list?
Posted: Thursday 27 October 2016 23:28
by Egregius
Where does the actual temperature comes from?
Posted: Sunday 30 October 2016 6:41
by JacquesMulders
It comes from whatever you update it with, same for the set temp...
Posted: Sunday 30 October 2016 11:23
by Egregius
So you need to update the device with a temperature of another device? But to do that you need to first read the setpoint, otherwise you can't update?
Don't get the advantage over a separate setpoint and thermometer then.
Posted: Monday 31 October 2016 14:41
by JacquesMulders
i want to use for example an fibaro flood sensor as a thermostat, so use the temp of the floodsensor and switch an floorheating valve open to heat the room. i think its a nice addition to it to have it combined in to 1 device instead of 1 temp sensor and 1 thermostat.
it is possible, with the link i provided in the second post. i think it would be nice if it could be in the dropdown list of the dummy hardware.
ive tried to compile domoticz with the adaption myself, but my knowledge of c++ and the domoticz root system is not enough to get it working.
Posted: Monday 31 October 2016 15:54
by JacquesMulders
Nevermind, in the dummy hardware the device is not working properly. i will try to do it via the evohome script hardware.
Posted: Monday 31 October 2016 18:58
by bloody2k
Hi JacquesMulders
Have you tried creating your dummy sensor trough Setup->Hardware->Dummy->Create virtual sensor?
Creating a dummy sensor here, I can select the type Thermostat Setpoint, which I would guess could do what you want to.
Can i ask you, how you control you floor heating valves?
I'm thinking of creating my own script/system to control my waterbased floor heating, but I cant seem to figure out the best way to control the valves, since they are working on 24v I have been thinking of a Qubino Flush relay.
What hardware are you using?
Posted: Tuesday 01 November 2016 15:32
by JacquesMulders
bloody2k wrote:Hi JacquesMulders
i saw the thermostat setpoint but this one doesnt have a combined temperature/setpoint.. thats what i like about the evohome devices.
i've now added the evohome via script hardware and that works perfect, i've build a script to import my tado and controll it from domoticz... i'm still in the process of building the set script, the temp value update script is ready.
on my floor heating mixer i have 230vac valves, so my plan was to build a script that just turns a fibaro on. thats only for the toilet/hallway, they may only get heat from the cv when the living room is also heated, i dont wat that the toilet turns on my cv... the rest of the house i control with tado, but i wanted them all in domoticz.
Posted: Thursday 02 February 2017 9:22
by mikkel75
I have the same problem - currently having 2 dummy devices per room; thermostat and temp sensor, both updated by Lua script.
I would very much like a dummy device that has both values exactly like the one you suggest.
I have tried you URL to create the Evo device, which works fine, but I'm missing the possibility from Domoticz GUI to set new SetPoint, like it's possible with other thermostats - is that possible?
How do you from Lua updat both setpoint and temperature on the EvoHome device?
Thanks.
P.S. I have a Roth floor heating system (Touchline) with an Ethernet interface. I have Lua code that read/write to that system via HTTP.
Posted: Thursday 13 April 2017 9:04
by PDP8
Is there any progress in this Dummy Thermostat? I would also like
to have a dummy thermostat to set temperatures @ certain times.
Regards, Roland
Posted: Friday 28 April 2017 6:27
by markjgabb
same here...ive only just realized this doesnt work....
ive added it from the dummy switches area but i cant find it to use it anywhere
Posted: Thursday 10 August 2017 9:41
by Qxlkdr
mikkel75 wrote: Thursday 02 February 2017 9:22
I also have a floor heating system (Roth Touchline) with an Ethernet interface.
Please explain how you read/write to the Roth system via HTTP. I would really appreciate it. Can you share the instruction and the LUA code?
Thanks in advance.
Posted: Monday 04 September 2017 9:41
by mikkel75
Here is my LUA code - roth.lua (placed in scripts/lua)
local roth_ip = "192.168.1.10"
package.cpath = package.cpath..';/usr/lib/x86_64-linux-gnu/lua/5.2/socket/?.so'
package.cpath = package.cpath..';/usr/lib/x86_64-linux-gnu/lua/5.2/?.so'
-- sudo ln -s /usr/share/lua /usr/local/lib/lua
-- install lua-socket
-- The Request Bin test URL: http://requestb.in/12j0kaq1
local http = require("socket.http")
local ltn12 = require("ltn12")
roth2device = { "Soveværelse", "Værksted", "LBad", "SBad", "Albert", "Emil", "Gang" }
function sendRequest(x)
local path = "http://"..roth_ip.."/cgi-bin/ILRReadValues.cgi"
local data = '<body><version>1.0</version><client>App</client><file_name>Controller</file_name><item_list_size>13</item_list_size><
item_list><i><n>G'..x..'.kurzID</n></i><i><n>G'..x..'.ownerKurzID</n></i><i><n>G'..x..'.RaumTemp</n></i><i><n>G'..x..'.SollTemp</n></
i><i><n>G'..x..'.OPMode</n></i><i><n>G'..x..'.WeekProg</n></i><i><n>G'..x..'.TempSIUnit</n></i><i><n>G'..x..'.SollTempMaxVal</n></i><
i><n>G'..x..'.SollTempMinVal</n></i><i><n>G'..x..'.SollTempStepVal</n></i><i><n>G'..x..'.OPModeEna</n></i><i><n>G'..x..'.WeekProgEna<
/n></i><i><n>CD.rooms['..x..']</n></i></item_list></body>'
local response_body = { }
local res, code, response_headers, status = http.request
method = "POST",
url = path,
source = ltn12.source.string(data),
headers =
["Content-Type"] = "text/xml",
["User-Agent"] = "Roth-Touchline.../1.05",
["Content-Length"] = string.len(data)
sink = ltn12.sink.table(response_body)
if (code == 200) then
return response_body[1]
return nil
function sendSetpoint(x, val)
local path = "http://"..roth_ip.."/cgi-bin/writeVal.cgi"
local res, code, response_headers, status = http.request( path.."?G"..x..".SollTemp="..val )
print( "sendSetPoint: "..res.."code: "..code)
return code
function updateRothDev(str, i)
-- Domoticz devices to update named "Gulv_Temp_xxxxx"
-- table converts Roth index to Domoticz device names
idx = string.find(str, "RaumTemp")
idx2 = string.find(str, "</v>", idx)
temp = string.sub(str, idx+15, idx2-1)
-- print( "Rum temp = " .. temp )
table.insert (commandArray, { ['UpdateDevice'] = tostring(otherdevices_idx["Gulv_Temp_"..roth2device[i]]).."|0|"..temp/100 } )
idx = string.find(str, "SollTemp")
-- print( "Rum set temp = " .. temp )
table.insert (commandArray, { ['SetSetPoint:'..tostring(otherdevices_idx["Gulv_Temp_"..roth2device[i].."_set"])]=tostring(temp/100) } )
--local temp = domoticz_applyXPath(response_body[1],'//body/item_list/i[contains(@n, "G1.RaumTemp")]/@v')
--domoticz_applyXPath(s,'//weatherdata/forecast/time[contains(@from,'15:00:00')]/@from')
-- Ex. response: "<body><version>1.0</version><client>App</client><file_name>Controller</file_name><item_list_size>13</item_list_size><item_list><i><n>G1.kurzID</n><v>2</v></i><i><n>G1.ownerKurzID</n><v>68</v></i><i><n>G1.RaumTemp</n><v>2172</v></i><i><n>G1.SollTemp</n><v>2100</v></i><i><n>G1.OPMode</n><v>0</v></i><i><n>G1.WeekProg</n><v>0</v></i><i><n>G1.TempSIUnit</n><v>0</v></i><i><n>G1.SollTempMaxVal</n><v>3000</v></i><i><n>G1.SollTempMinVal</n><v>500</v></i><i><n>G1.SollTempStepVal</n><v>0</v></i><i><n>G1.OPModeEna</n><v>1</v></i><i><n>G1.WeekProgEna</n><v>1</v></i><i><n>CD.rooms[1]</n><v></v></i></item_list></body>"
Here is a timed script to update all devices every 15 minutes (script_time_Roth.lua in domoticz/lua):
local m = os.date('%M')
if (m % 15 == 0) then
-- print('The 15 minute script interval reached')
-- Call your function here that shall run every 15 minutes
dofile("/home/hac/domoticz/scripts/lua/roth.lua")
table.insert (commandArray, { ['Variable:RothUpdateActive'] = '1' } )
for i=1,#roth2device do
str = sendRequest( i-1 ) --Roth table is 0 based
if ( str ~= nil ) then
print( "Roth HTTP access failed: "..i)
table.insert (commandArray, { ['Variable:RothUpdateActive'] = '0' } )
Remember to create dummy devices and change the scripts were needed...
Hope it helps
/Mikkel
Posted: Friday 26 January 2018 15:06
by buzzzy
Mikkel, thanks for sharing the code. Also having a Roth device, I'd like to be able to plot the temperature data. I can pull the data using
curl -s -k -X "POST" -H "Content-Type: text/xml" -H "User-Agent: SpiderControl/1.0 (iniNet-Solutions GmbH)" --data-binary $"<body><item_list><i><n>G0.RaumTemp</n></i><i><n>G1.RaumTemp</n></i><i><n>G2.RaumTemp</n></i><i><n>G3.RaumTemp</n></i><i><n>G4.RaumTemp</n></i><i><n>G5.RaumTemp</n></i></item_list></body>" "http://192.168.2.10/cgi-bin/ILRReadValues.cgi"
Now, being new to Domoticz I cannot find any complete tutorials on how to integrate the full thing, script, hooking up with devices etc in Domoticz. Any more info you can share?
