Array of strings and their indexing in lua
flabrosse
Post by flabrosse »
All,
I'm rather new to lua, but not too programming.
To loop through heating zones in trying to put their names in an array that I can then iterate over to do something for each of them. Not knowing the syntax I read lua.org to try to learn the language.
So i try something like:
local names={"kitchen", "bedroom"}
and tried to index it in a for loop. I at that point realised that table.getn(names) does not work. Also names[0] or names[1] are nil.
What am I missing?
Is there a better reference for lua as interpreted in domoticz?
Cheers
Fred
Egregius
Domoticz version: v2024.7
Re: Array of strings and their indexing in lua
Post by Egregius »
You can also use php for your scripts.
I use several arrays there to calculate stuff for each room.
jvdz
Domoticz version: 4.107
Post by jvdz »
This works fine:
local names = {"kitchen", "bedroom"}
print(names[1])
print(names[2])
Jos
flabrosse
Post by flabrosse »
I does indeed! I think I missed it because I started reading from index 0, not being sure what the first index would be, and the script failed (trying to create a string from nil, never reaching index 1.
Thanks for that!
Fred
