Danfoss 014G0002 - Doesn`t work
hasan
Post by hasan »
HI,
maybe i bought wrong valve :(
I have 014G0002 with SW4.02... and OpenZwave is showing: Danfoss Unknown: type=8005, id=0002
and it doesn`t work :( is there any way how it should work?
LouiS22
Re: Danfoss 014G0002 - Doesn`t work
Post by LouiS22 »
hasan
Post by hasan »
F*ck.... I s there any way how to downgrade firmware in Danfoss valve? It should be a way...
LouiS22
Post by LouiS22 »
hasan wrote:F*ck.... I s there any way how to downgrade firmware in Danfoss valve? It should be a way...
No, there's no way. You have need the correct version (the ones with ending number 13).
hasan
Post by hasan »
OK... thanks... API for Danfoss LINK CC is not available so integration into Domoticz is not possible...
marcelr
Domoticz version: svn 2470
Post by marcelr »
Not so fast.
If the hardware is the same, you should be able to reflash the TRV with other software. I'm currently trying this for my TRVs (danfoss 014G0013 or thereabouts). I want to transplant the popp code onto the original danfoss TRVs. Just got the AVR-ISP-MK2 programmer working. Finding the right connection for the PCB was easy. Will keep you posted.
best,
marcelr
LouiS22
Post by LouiS22 »
Not so fast.
best,
marcelr
What's the point flasing a different software into a different model? AFAIK Popp's hardwaree is different (there's a built-in thermometer). So you won't get anything, because your hardware doesn't contain the thermometer. Besides, your warranty will be void, etc. Third: I really do think that OP's hardware is a bit different than the one with 13 ending).
marcelr
Post by marcelr »
It's exactly the same device (just doesn't have danfoss embossed in the housing). Same hardware, same microcontroller, just a different brand name (ZWE at the inside, popp on the box and accompanying booklet). The danfoss LC-13 also has the same built-in temperature sensor, it's hard for a TRV to control a temperature if it doesn't know what it actually is.
best,
marcelr
LouiS22
Post by LouiS22 »
best,
marcelr
Then good luck for the reflashing - still, it's not something an average user can achieve. But now I understand your point (and sorry for being a bit sarcastic on the hardware thing) :)
marcelr
Post by marcelr »
Just had a look at the flash settings. It's not going to happen any time soon; the code's locked inside the microcontroller, no way to get it out :-(.
best,
marcelr
LouiS22
Post by LouiS22 »
best,
marcelr
Then I was right - it's ALMOST impossible (at least for an average user) to change/reflash the firmware :(
