Hoi,
Is it possible to configure Domoticz to send me a notification whenever thermosmart "tells" the boiler to heat up the room?
Thermosmart notification
schulpr
Re: Thermosmart notification
I would like that too.
Bikey
- Domoticz version: 2020.x
In order to be able to do that, Domoticz would have to know if the thermostat activated the heating system.
Or even better, with an OpenTherm compatible heating system, Domoticz could read out the OpenTherm status from the heating system.
If this data would be available in an additional Device you could set all kinds of actions based on this in Domoticz. I myself would very much like to use this to log actual usage of the heating system.
This data is available and can be requested with the ThermoSmart API.
So, question to the developer of the ThermoSmart plug-in, would be: could you make this available?
