Hi guys,
I've created a "Temp + Humidity" device from a dummy hardware.
I want to sent to it the value from Node-Red from another machine. I've tried sending this data in multiple ways with MQTT to domoticz/in, but without any luck.
How do I need to format the MQTT to send the temp and humidity?
Thanks!!!
Andrea
MQTT format for Temp & humidity
Re: MQTT format for Temp & humidity
Using this format
"Battery" : 100,
"RSSI" : 12,
"dtype" : "Temp + Humidity",
"id" : "13825",
"idx" : 93,
"name" : "Badkamer",
"nvalue" : 0,
"stype" : "WTGR800",
"svalue1" : "22.5",
"svalue2" : "58",
"svalue3" : "1",
"unit" : 0
from this post http://www.domoticz.com/forum/viewtopic ... ure#p93407, I see the temperature updating with the nvalue, not svalue1 and just the temperature not the humidity
If I listen to all the MQ
Domoticz doesn't read the svalues
"Battery" : 100,
"RSSI" : 12,
"id" : "13825",
"idx" : 93,
"nvalue" : 0,
"svalue1" : "22.5",
"svalue2" : "58",
"svalue3" : "1",
"unit" : 0
domoticz/in {"idx" : 23,"nvalue" : 11,"svalue1" : 21.2,"svalue2" : 52.5}
domoticz/out {
"Battery" : 255,
"RSSI" : 12,
"id" : "82022",
"idx" : 23,
"name" : "Temp+Hum",
"nvalue" : 11,
"stype" : "THGN122/123, THGN132, THGR122/228/238/268",
"unit" : 1
No one knows??? Come on, I don't believe it!
Toyman
{ "idx" : 74,
"nvalue" : 0,
"svalue" : "21;35;1"}
"nvalue" : 0,
YES YES YES!
Thanks Toyman!!!
Though it was really elementary...
Thanks Toyman!!!
Toyman
You are welcome. Actually, it's all in Domoticz wiki
ben53252642
Solution for sending Temp + Hum + Baro to a single sensor in Domoticz via MQTT
viewtopic.php?f=68&t=23607&start=40#p189095
ben53252642
To send only Humidity to a Humidity Sensor in Domoticz via MQTT, I spent over an hour trying to get this to work (solution):
It's sensitive to quotes "", this is what I use in a Node-Red function:
msg.payload.idx = 1211;
msg.payload.nvalue = humidity;
msg.payload.svalue = "0";
The nvalue cannot be sent as a string.
