Wi-Fi or rflink wall thermostat/ programmable timer
cherowley
Post by cherowley »
Are there any wall thermostats which have a programmable timer compatible with RFlink or have a WiFi api?
On ebay there are devices as low as £15 which have a rf remote but of course not much use if rflink doesn't support it :)
Wi-Fi devices like nest etc are overkill for my needs, not to say a more basic (cheaper) Wi-Fi device wouldn't fit the bill as long as it has an api..
Looking for a drop in replacement for the standard honeywell wall stat, by this I mean the relay is on board and not a separate box.
Thought about building one using esp8266 etc but just not happy enough with their stability ;)
deennoo
Re: Wi-Fi or rflink wall thermostat/ programmable timer
Post by deennoo »
You can have a look to a drayton rf programmable room thermostat who run on 433mhz and with RFLink.
Digistat rf series do the job on 433 mhz.
http://www.draytoncontrols.co.uk/produc ... Thermostat
Have a look at installation guide it confirm 433mhz
http://domo-attitude.fr
cherowley
Post by cherowley »
Thanks deenoo :)
Had a look but not quite what I'm after as it's a two box solution and still nearly £100 :)
deennoo
Post by deennoo »
Fact is that screen box is just a rf sender, second one is an rf reciever.
Got an europan version (868 switch to 433, rf module are just plug without soldering). And it'd works great !
European version are call : Eberle instat 868.
Easy to find on nl and germany
cherowley
Post by cherowley »
I think I'm going to write a new plugin for ESPEasy and have it run on a Sonoff as they do seem to be quite stable..
I'll leave it running for a week or 2 and see howit gets on..
Advantage of this is I can make it fully domoticz compatible and will cost me zero as already have the sonoff and temp sensor :)
Dezz
Post by Dezz »
deennoo wrote:You can have a look to a drayton rf programmable room thermostat who run on 433mhz and with RFLink.
I have exactly this kit. RFLink sees the signals when I press the buttons for up/down on the thermostat but it's just a long string of codes i.e.
Call for heat ON
20;B9;DEBUG;Pulses=58;Pulses(uSec)=270,420,420,420,420,420,420,420,420,420,930,930,420,420,420,420,420,420,420,930,930,420,420,930,930,420,420,930,420,420,420,420,420,420,420,420,420,420,930,930,420,420,420,420,420,420,420,420,930,420,420,420,420,930,930,930,420,6990;
20;BA;DEBUG;Pulses=58;Pulses(uSec)=420,420,420,420,420,420,420,420,420,420,930,930,420,420,420,420,420,420,420,930,930,450,360,930,930,420,420,930,420,420,420,420,420,420,420,420,420,420,900,930,420,420,420,420,420,420,420,420,930,420,420,420,420,930,930,930,420,6990;
20;BB;DEBUG;Pulses=58;Pulses(uSec)=420,420,420,420,420,420,420,420,390,420,930,930,420,420,420,420,420,420,420,930,930,420,420,930,930,420,420,930,420,420,420,420,420,420,420,420,420,420,930,900,420,420,420,420,420,420,420,420,930,420,420,420,420,990,870,930,420,6990;
Call for heat off
20;B3;DEBUG;Pulses=58;Pulses(uSec)=480,420,420,420,420,420,420,390,420,420,930,930,420,420,450,390,420,420,420,930,930,420,420,930,930,420,420,930,420,420,420,420,420,420,420,420,420,420,420,420,420,420,420,420,420,420,420,420,930,930,930,420,420,900,930,930,420,6990;
20;B4;DEBUG;Pulses=58;Pulses(uSec)=420,420,420,420,420,420,420,450,390,420,930,930,420,420,420,420,420,420,420,930,930,420,450,870,930,420,420,930,420,420,420,390,420,420,420,420,420,420,420,420,420,420,420,390,420,420,420,420,930,930,930,420,420,930,930,930,420,6990;
20;B5;DEBUG;Pulses=58;Pulses(uSec)=450,420,420,420,420,420,420,420,420,420,930,930,420,420,420,390,420,420,420,930,930,420,420,930,930,420,420,930,420,420,420,420,420,420,420,420,420,420,420,420,390,420,420,420,420,420,420,420,930,930,930,420,420,930,900,930,420,6990;
Any idea how I get this into Domoticz please?
deennoo
Post by deennoo »
Just send debug to Stuntteam, he will create device !
http://www.nemcon.nl/blog2/contact
davidlightsa
Post by davidlightsa »
cherowley wrote:Thanks :)
Hi Cherowley, Did you ever manage this? I am keen to do the same.
