IP Blacklist
emme
Domoticz version: latest
IP Blacklist
Post by emme »
it might be possibile to add a blacklist of IPs and networks able to connect to the server?
As per the whitelist IPs that does not need authentication, I would like to ban some IPs that are trying to connect to the server.
Actually I've rejected them in my firewall... but I was wondering if such option could be added to domoticz
thanks
ciao
M
"We always done this way"
SweetPants
Re: IP Blacklist
Post by SweetPants »
If you are connected through a (NAT) Firewall, there is no use for a blacklist. The src-ip will always be the firewall
emme
Re: IP Blacklist
Post by emme »
mmmh....
not really sure about it....
2016-10-03 12:55:51.530 Incoming connection from: 62.94.xx.yy
SweetPants
Re: IP Blacklist
Sorry, misread your question. For incomming data you probably do port forwarding? Then the src-ip is preserved and will be send to Domoticz. Best is to let your Firewall blacklist these unwanted IP's at the frontdoor. That is where Firewalls are for
emme
Re: IP Blacklist
Post by emme »
many thanks....
at last... It was the same answer I gave myself... but I was just asking :P :P
ciao
M
