Getting started, what is the optimal z-wave device to start with?
dantman
Post by dantman »
I'm getting started with a little home automation and after comparing my options for the controller I've decided to go with a Domoticz, a new Raspberry PI, and a z-wave device.
I've got a programming background so I'm fine with Domoticz, but I don't want to have to fiddle with a z-wave device that is difficult to get to work with Domoticz and Raspberry PI.
Can someone recommend a z-wave device which:
  • Is known to work with the Raspberry PI (GPIO and USB are both fine)
  • Is known to be compatible with Domoticz and easily setup with pre-existing instructions (I'm fine with changing a little system config, but not major patches to Domoticz)
  • Presumably, works well with OpenZwave (I saw some mentions in the forum of z-way needing additional configuration in z-way to get devices setup)
  • Is lnown to be stable and not have crashing issues (Like the RaZberry is reported to)
  • Has a reasonable price point for the features that'll Domoticz will use (I saw one USB controller is ~$50; If all the stable USB controllers are $50 that's fine, but if others cost less than that and are just as stable I don't want to bother paying the extra money for nothing)
  • Is available to the Canadian market
deejc
Domoticz version: 3.5641
Re: Getting started, what is the optimal z-wave device to start with?
Post by deejc »
I have an aeon z stick that I got from eBay second hand and it's worked with everything I have thrown at it , although I think the us and Canadian z wave frequencies are different to Europe so that may be a factor
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
dantman
Post by dantman »
deejc wrote:I have an aeon z stick that I got from eBay second hand and it's worked with everything I have thrown at it , although I think the us and Canadian z wave frequencies are different to Europe so that may be a factor
For Canada the Gen 5 seems to be $60 CAD (https://www.aartech.ca/zw090-zwave-usb-stick.html)
eBay listings are selling the "series 2" for nearly the same price:
http://www.ebay.ca/sch/i.html?LH_BIN=1& ... ck&_sop=15
So I probably won't get a second hand discount.
But if no-one else knows of a reliable stick that costs less, then I'll go with that.
blackdog65
Post by blackdog65 »
I use the Z-Stick too and have had no problems with it. The best thing about it is that it can be unplugged and positioned next to a new device for inclusion if needed.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
cogliostrio
Post by cogliostrio »
blackdog65 wrote:I use the Z-Stick too and have had no problems with it. The best thing about it is that it can be unplugged and positioned next to a new device for inclusion if needed.
This only work for non-secure inclusion. Secure inclusion like door locks will need to be included with controller connected to R-PI/PC.
I got the UZB controller, havnt had any problems with it. I would recommend a gen5/zwave+ interface. Either way, their all easy to set up.
