I've just connected my RGBW strip up to my Fibaro RGBW controller - that's all, i've not played with the configs or anything, just added the device so i can switch the colours.
When setting a colour, i get the wrong colour.
Its a RGBW strip.
Green wire to G port
Red wire to R
blue to B
white to W
The black wire from the LED strips is connected to the 12v.
PSU white wire is connected to GND
PSU red wire is connected to 12v (With the black wire from the LED strip)
Is this setup good?
Colours are not accurate.
Domoticz 3.5691.
Cheers
Fibaro RGBW Controller setting strip wrong colours
stuiow
- Domoticz version: 3.6857
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
- emme
- Domoticz version: latest
Re: Fibaro RGBW Controller setting strip wrong colours
I know this could be a stupid question but....
Are you sure the red wire goes to the red led, the green to the green and the blue to the blue?!
I had a cheap led stripe that was wired differently
"We always done this way"
stuiow
Really? Jeez. Common sense doesnt apply here then?
I'll have to go and have a play then, agh.
- emme
common sens used to be the right choice....
But I had experience with bad workers
