Beginner not able to start nor Lua or Blockly demo script
Posted: Tuesday 13 September 2016 17:40
I'm just starting to use Domoticz so my problem is probably trivial:
My config: RaspBerry PI3 with one PIFace 2, its variable are defined in the config file and properly appears as devices
Scripts enabled
I would like to print something into the log file when I change the value of one of the variable but it seems that scripts doesn't start. I tried with:
- LUA event script in Domoticz interface
- blockly script
- example LUA script in the Lua scripts directory (double check the name)
I changed the value from Domoticz devices page and using the switch on the PiFace switches.
Nothing works and I'm short of ideas.
Could you, please, help me ?
Kind regards
Scripts enabled
- blockly script
Kind regards
