I'm just starting to use Domoticz so my problem is probably trivial:
My config: RaspBerry PI3 with one PIFace 2, its variable are defined in the config file and properly appears as devices
Scripts enabled
I would like to print something into the log file when I change the value of one of the variable but it seems that scripts doesn't start. I tried with:
- LUA event script in Domoticz interface
- blockly script
- example LUA script in the Lua scripts directory (double check the name)
I changed the value from Domoticz devices page and using the switch on the PiFace switches.
Nothing works and I'm short of ideas.
Could you, please, help me ?
Kind regards
Beginner not able to start nor Lua or Blockly demo script
mscory
Re: Beginner not able to start nor Lua or Blockly demo script
I've just understood:
my devices were just located within "setup" --> "devices". I had to define them as "switches" by pushing the small edit icon on the "setup/devices" screen.
