Hikvision PIR sensor
philchillbill
Post by philchillbill »
Newbie here, just installed Domoticz on my Synology NAS and adding some devices. I have a DS-2CD2432F-IW ip-cam which has a built-in PIR for motion detection. I can read out its status by checking this URL in my local network:
http://192.168.0.15/IO/outputs/1/status/
which will return XML looking like
<?xml version="1.0" encoding="UTF-8"?>
<IOPortStatus xmlns="http://www.hikvision.com/ver10/XMLSchema" version="1.0">
<ioPortID>1</ioPortID>
<ioPortType>output</ioPortType>
<ioState>inactive</ioState>
</IOPortStatus>
where the 'inactive' changes to 'active' when motion is detected.
Any idea how I can set up this PIR as a trigger device in Domoticz? I added the cam as a camera with image URL for snapshots but have no idea where to add the PIR sensor.
Thanks, Phil
cogliostrio
Re: Hikvision PIR sensor
Post by cogliostrio »
Have you seen this post here by the user nayr?
Doesn't seem to be finish with the hikvision support yet, but it might give you something to proceed from.
philchillbill
I actually got this functionality working myself now, having setup an Intel NUC running Ubuntu as my serious Domotica server. The clue was to run a curl command from a perl script on a crontab schedule to check the ipcam's PIR-url. I did this as follows, with a backtick shell execution from perl:
curl -s -u username:password http://192.168.0.15/IO/outputs/1/status &> /dev/stdout | grep ioState
and checked for 'active' or 'inactive' in the resulting status using a regex. Depending on this outcome, I used another curl to set the status of the virtual/dummy switch in Domoticz:
curl -s "http://$domoticz/json.htm?type=command&param=switchlight&idx=$idxvalue&switchcmd=On
or
curl -s "http://$domoticz/json.htm?type=command&param=switchlight&idx=$idxvalue&switchcmd=Off
depending on the value of ioState returned from the first curl.
Note: $domoticz is the IP-address of my Domoticz server and $idxvalue is the idx assigned to my virtual switch.
If anybody wants to try this themselves I can write it up fully.
Ipsonius
Post by Ipsonius »
Phil, maybe do you know another way to get the PIR status, I'm already using the I/O port with a door contact :?
Ah, if you have the full script it will be usefull, I have limited skills with bash...
Thx in advance!
philchillbill
Well I actually did it in Perl, not bash. And as crontab jobs only run once a minute I let the perl loop a few times with sleeps in between to achieve more regular updates. Here's my script:
#!/usr/bin/perl
    use v5.14;
    use LWP::Simple;
    use JSON qw( decode_json );
    use utf8;
    use feature     qw< unicode_strings >;
    # Configuration section, please update to your values
    my $domoticz = "192.168.178.12:8080";  # ip and port of your Domoticz server
    my $domo_cmd = "http://$domoticz/json.htm?type=devices&filter=all&used=true&order=Name";
    # Hash of (device idx, device name) - I only have one but it can be scaled
    my %switches=(90=>'HallPIR');
    my $debug=0;
    my $cnt=1;
    do {
     $cnt++;
     my $json = get( $domo_cmd );
     die "Could not get $domo_cmd!" unless defined $json;
     my $decoded = JSON->new->utf8(0)->decode( $json );
     my @results = @{ $decoded->{'result'} };
     my @tab;
     foreach my $f ( @results ) {
      if ($f->{"SwitchType"}) {
            $tab[$f->{"idx"}]=$f->{"Status"};
     foreach my $k (keys %switches) {
            my $device=$switches{$k};
            my $res=`curl -s -u username:passwod http://192.168.178.15/IO/outputs/1/status &> /dev/stdout | grep ioState`;
            if ($res=~m/\>active/) {print "Active: $tab[$k]\n"} else {print "Inactive: $tab[$k]\n"};
            if (($res=~m/\>active/)&&($tab[$k] eq 'Off')) {
                    #If device answered to polling and device status is Off, turn it On in Domoticz
                    if ($debug) {print "$k is On\n"};
                   `curl -s "http://$domoticz/json.htm?type=command&param=switchlight&idx=$k&switchcmd=On"`;
            } elsif (($res=~m/inactive/)&&($tab[$k] eq 'On')) {
                    #If device did NOT answer to polling and device status is On, turn it Off in Domoticz
                    if ($debug) {print "$k is Off\n"};
                   `curl -s "http://$domoticz/json.htm?type=command&param=switchlight&idx=$k&switchcmd=Off"`;
            } else {
                    if ($debug) {print "Do nothing: $k is ".$tab[$k]."\n";}
     sleep 5;
    } until ($cnt>10);
    $cnt=1;
philchillbill
The purist in me didn't like going out to the shell from my perl script so I rewrote it using LWP::UserAgent instead and now it's more elegant. It also updates the Domoticz log when it sees motion. I now run it every 15 minutes on a cron job and it sleeps every 5 seconds until it hits the 15 minute mark.
#!/usr/bin/perl
# Reads the state of the PIR detector in a Hikvision camera and if it sees motion then a switch in Domoticz is set.
use LWP::UserAgent;
no warnings 'uninitialized';
$domo_url = '192.168.178.12:8080';
$idx=90;
$hik_url = '192.168.178.15';
$PIR_uname = 'hallpir';
$PIR_pwd = 'passwordforhikcamera';
$runs=0;
do { # loop 180 times with sleep every 5 seconds
 $runs++;
 $ua=LWP::UserAgent->new;
 $ua->timeout(5);
 $ua->credentials( $hik_url.':80', 'DS-2CD2432F-IW', $PIR_uname, $PIR_pwd );
 $response=$ua->get('http://'.$hik_url.'/IO/outputs/1/status');
 unless ($response->is_success) {
  $err=$response->status_line;
  $msg_url='http://'.$domo_url.'/json.htm?type=command&param=addlogmessage&message=HIKVISION%20$err';
  $r=$ua->put($msg_url);
  die $response->status_line;
 $res=$response->decoded_content;
 $triggered = ($res=~m/\>active/);
 if ( $triggered && !$set ) {
  $msg_url='http://'.$domo_url.'/json.htm?type=command&param=addlogmessage&message=Hikvision%20PIR%20Active';
  $switch_url='http://'.$domo_url.'/json.htm?type=command&param=switchlight&idx='.$idx.'&switchcmd=On';
  $r=$ua->put($switch_url);
  $set=1;
 else {
  if ( !$triggered && $set ) {
   $msg_url='http://'.$domo_url.'/json.htm?type=command&param=addlogmessage&message=Hikvision%20PIR%20Inactive';
   $switch_url='http://'.$domo_url.'/json.htm?type=command&param=switchlight&idx='.$idx.'&switchcmd=Off';
   $set=0;
 sleep 5;
} while ($runs < 180); # runs for 15 mins on a cron schedule so auto-exits after 180x5 seconds = 15 mins
