Look at the two pictures here viewtopic.php?f=6&t=13299
First is coming from a device showing only Watt(left side) and second is from a device showing both Watt(right side) and kWh.
To make it more consistent Watt should always be on left or right side.
I don't know if that is possible to change
Maybe other devices will get not consistent if you change to always have Watt on same side
Consistent of Unit
