The SD card in my Pi got corrupted due to a power interruption. I tried to recover, but the Pi still won't boot. I am still able to access all data on the card though (on another computer obviously).
Is there a way to somehow save my Domoticz settings?
So my plan is to re-install Domoticz, but transfer my settings from my current (corrputed) SD-card. Which files do I need to copy (if at all possible)?
How to recover settings
- Egregius
- Domoticz version: v2024.7
Re: How to recover settings
At least make a copy of the complete Domoticz folder (or even the complete /home/pi folder).
You should have than that before, backup, backup, backup,....
vco1
Thanks. I know I should have made a backup (or an image of the SD card).
Are all Domoticz settings stored somewhere in the home/pi folder? Or are there other places where Domoticz stores (user)data? I don't mind creating a new image, but I'm not looking forward to setting up my whole environment (even though it's not that big).
Sneezydevil
Domoticz stores almost everything in the domoticz.db file. Its located in /home/pi/domoticz so if you backup /home/pi/ like Egregius said, you should be pretty safe. If you added scripts you probably know were you saved them
vco1
I was unable to restore the database. Although I could copy the files from the SD card, it seemed domoticz.db was corrupt (I got the the message that sqlite couldn't open an encrypted database when I tried to open it directly with sqlite on the command line). Adding all deveices anew was relatively easy though. I'm almost there.
As for the scripts, I don't know where they are. At least not in the scripts directory. Could Lua scripts be in some other directory than scripts too?
