Hi there. I'm new to home automation, and I'd like a little help setting up a Z-wave network, please.
I have a UZB1 (https://www.z-wave.me/index.php?id=28) connected to a Synology NAS. I've installed the pre-compiled Domoticz (apparently including OpenZWave) from here: http://www.jadahl.com/domoticz_stable_6/
In the Domoticz interface, under the Setup > Hardware tab, I can add the OpenZWave USB device. When I attempt to Include Node, Domoticz starts searching, but my device never connects.
I'm now using the same UZB1 on a Raspberry Pi; from here I can successfully add the device. I'm therefore pretty sure that the problem is with my Synology setup.
Have I missed a step of my installation? Am I missing some USB drivers? Do I need to change a setting in my Diskstation or Domoticz interface? Has anyone successfully used a UZB1 with a Synology NAS before?
I'd appreciate any help!
Can a UZB1 be made to work on a Synology NAS?
harm74
- Domoticz version: 3.5877
Re: Can a UZB1 be made to work on a Synology NAS?
Same problem here. Also didn't had any luck with installing domoticz on my synology 214play using the zwave.me transceiver. How can domoticz start searching as you include a node? Did you solve the problem? Thanks.
