Help needed with Milight LED strip controller
Posted: Monday 29 August 2016 9:46
by Robin20VT
Bought a Milight RGBW ledstrip controller, hooked it up, the thing turns on, but I don't seem to can pair it to domoticz.
I've got several Milight bulbs hanging and paired so the procedure is well known. But when I plug in de LED controller, the white leds turn on, I hit " OK " in Domoticz with command: 10;MiLightv1;F505;01;34BC;PAIR; and nothing happens.
I happen to have bought 2 of these controllers, but none of them seem to be working. Am I doing something wrong here?
Thank you in advance.
Domoticz (latest Beta) on Rpi with RFLink R42 + Milight add-on on USB.
Re: Help needed with Milight LED strip controller
Posted: Sunday 12 February 2017 15:22
by icibt
Robin20VT wrote:Hi all,
I am facing the same issue right now.... have you found a solution?
Posted: Tuesday 14 February 2017 21:10
by Robin20VT
Bit late.. But not yet, I'm awfully late but I'm still going to send one of my controllers to Stuntteam so they can perhaps sort it out..
Posted: Tuesday 14 February 2017 21:34
by sijones
Which bridge version are you using? The new bridge (think V5) isn't supported yet.
Posted: Tuesday 14 February 2017 21:36
by Robin20VT
I've had substantial mailcontact with Stuntteam. Mine should be supported, but doesn't work at the moment.
It's not a bridge (I think) but a loose controller, which could be operated with a Milight remote control (which I don't have)
