Bought a Milight RGBW ledstrip controller, hooked it up, the thing turns on, but I don't seem to can pair it to domoticz.
I've got several Milight bulbs hanging and paired so the procedure is well known. But when I plug in de LED controller, the white leds turn on, I hit " OK " in Domoticz with command: 10;MiLightv1;F505;01;34BC;PAIR; and nothing happens.
I happen to have bought 2 of these controllers, but none of them seem to be working. Am I doing something wrong here?
Thank you in advance.
Domoticz (latest Beta) on Rpi with RFLink R42 + Milight add-on on USB.
Help needed with Milight LED strip controller
Re: Help needed with Milight LED strip controller
I am facing the same issue right now.... have you found a solution?Robin20VT wrote:Hi all,
Robin20VT
Bit late.. But not yet, I'm awfully late but I'm still going to send one of my controllers to Stuntteam so they can perhaps sort it out..
sijones
- Domoticz version: Git
Which bridge version are you using? The new bridge (think V5) isn't supported yet.
Robin20VT
I've had substantial mailcontact with Stuntteam. Mine should be supported, but doesn't work at the moment.
It's not a bridge (I think) but a loose controller, which could be operated with a Milight remote control (which I don't have)
