Small issue with overlayfs
jannl
- Domoticz version: 2026.1.x
I just activated the overlayfs with the wiki, everthing looks to work great.
When I issue a 'service saveoverlays sync', everything seems to go ok, however I get an error near the end of the script: '/etc/init.d/saveoverlays: 107: [: rw: unexpected operator'
Line 107 looks ok, so not sure what to do here.
Any clues?
Any clues?
hansrune
Long time sine, but I think i fixed that. Please try downloading the service script again. Alternatively, try:
sudo bash -x /etc/init.d/saveoverlays sync
.... to debug more detailed.
jannl
Re: Small issue with overlayfs
thx, will try that later this week.
I downloaded the saveoverlays last saturday.
When I look at the file now, I see a space between #! and /bin/sh, which shouldn't be there I think (shebang line)
Furthermore, this should indicate /bin/sh is used instead of bash.
I will come back to this.
jannl
Issuing the command directly does not seem to give the error.
What presents the error is:
Error is in the saveoverlays
sudo su -
mount -o remount,rw /
mount -o remount,ro /
guiguid
Same bug :
pi@raspberrypi:/tmp $ sudo su -
root@raspberrypi:~# mount -o remount,rw /
root@raspberrypi:~# /etc/init.d/saveoverlays sync
[....] Syncing overlay filesystem sync: saveoverlays[info] Syncing /home to /home_org ....
[info] Syncing /var to /var_org ....
[info] Saving fake-hwclock.
[info] Sync changes to disk.
. ok
root@raspberrypi:~# mount -o remount,ro /
/etc/init.d/saveoverlays: 107: [: ro: unexpected operator
. ok
root@raspberrypi:~#
guiguid
fixed by :
Have nice day
-#!/bin/sh
+#/bin/bash
jannl
If that is the exact change, the line #/bin/bash does not do anything, because it is commented out.
