How can I read the sensor value in LUA
Rolo
Domoticz version: 3.8153
Post by Rolo »
Working on a Lux meter to connect to domoticz, the hardware works, I have the sensor available in Domoticz and it shows changing lux values. But now I want to interact with this lux value to make smart dusk sensors and light switches. This is were the LUA scripts come in, I have read the wiki, I understand the basics but can't get the Lux value written in to a user variable. Can someone point me in the right direction ?
This is what I have now :
------ Variables to edit ------
devicename = "Lux meter" --Name of the device
debug = true
-- End of variables to edit --
if (devicechanged[devicename]) then
	if (debug) then
	    print("Following values are coming in from device: ")
		for i, v in pairs(devicechanged) do print(i, v) end
	-- how can I read the lux value	from the sensor ?
	commandArray['Variable:LUX']='1234'  -- fixed value for now, this should be the current lux
This is the output in the log
2016-08-20 10:49:15.004 LUA: Following values are coming in from device:
2016-08-20 10:49:15.004 LUA: Lux meter_Utility
2016-08-20 10:49:15.004 LUA: 508
2016-08-20 10:49:15.006 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Lux meter.lua
So the lux value is there, at line 3, next thing is to write it to the user variable. \
Thanks !
jvdz
Domoticz version: 4.107
Re: How can I read the sensor value in LUA
Post by jvdz »
This should work:
luxsensor = "Lux meter_Utility"
if (devicechanged[luxsensor]) then
   print( " ####lux debug: "..devicechanged[luxsensor]
   commandArray['Variable:LUX']=devicechanged[luxsensor]
Jos
Rolo
Post by Rolo »
Thanks, it works (half..)
Debug shows correct value :
2016-08-20 12:30:36.862 LUA: ####lux debug: 361
But then an error :
2016-08-20 12:22:28.791 Error: EventSystem: commandArray in script /home/pi/domoticz/scripts/lua/script_device_Lux meter.lua should only return ['string']='actionstring' or [integer]={['string']='actionstring'}
Looks like it's not the correct type.
jvdz
Post by jvdz »
ah..ok, that means you need to convert it to string like:
commandArray['Variable:LUX']=tostring(devicechanged[luxsensor])
Jos
Rolo
Post by Rolo »
BIngo, works !
Thanks, I do some coding in C but this LUA takes some getting used to. Now next thing is making a fancy dusk switch.
This is the completed script :
   print( " ####lux debug: "..devicechanged[luxsensor])
