Detecting meters that no longer update
WebSpider
- Domoticz version: 4834
Hi!
I have a meter (Everspring AN181, Z-Wave) that measures power in a shed. However, sometimes someone accidentally turns off the power to the shed, and stuff like a fridge doesn't like that.
Is there any way I can fire events on the latest update of a device, or the absence of a Z-Wave node from the mesh?
- Egregius
- Domoticz version: v2024.7
Re: Detecting meters that no longer update
If you have a look at my pass2php script you'll find examples of that.
I receive message if a node is marked as dead and also when a devices hasn't sent anything for 4 hours.
WebSpider
Thanks for the reply. I just looked at it, and if I get it right, you are using lua, to pass openzwave values to php, which then starts influencing Domoticz .. Why not use the commandArray['SendNotification'] (for me) or commandArray['UpdateDevice']?
Anyway, thanks a bunch for pointing out Lua can catch this
- Egregius
Because I don't know anything about lua and I love PHP code.
the pass2php lua script passes all statusses, updatetimes, svalues etc to a php script. There it's put in arrays so they can be used to trigger anything you can imagen.
WebSpider
This turned out to be very doable in the native LUA, please find snippet below
function timedifference (s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
upd_delta = timedifference (otherdevices_lastupdate['Verbruik Vrieskist'])
print("Vrieskist not updated since "..upd_delta.." seconds");
if (upd_delta > 900) then
commandArray['SendEmail']='Vrieskist problemen#Al '..upd_delta..' seconden geen update van de vrieskist meer ontvangen#[email protected]'
end- bizziebis
- Domoticz version: 3.8805
This works, however if the condition is true it will send you an email every minute (if used as a time script).
I've added an uservariable which is set when the email is sent. From this variable I check if the time difference since last update is > 1800. So I get an email every 30 minutes.
- havnegata
- Domoticz version: V4.10162
Re: RE: Re: Detecting meters that no longer update
Can you please post the code for this! I have a couple of scripts with notifications beeing sent every minute, and would really like to avoid thisbizziebis wrote: I've added an uservariable which is set when the email is sent. From this variable I check if the time difference since last update is > 1800. So I get an email every 30 minutes.
- bizziebis
Sure, just like this:
send_notification() is my own function, just replace it by something that will send you a notification.
'Sensor1 Notification' is an Uservariable of the type string which has to be created first.
difference = timedifference(otherdevices_lastupdate['Sensor1'])
if difference > 3700 then
if timedifference(uservariables_lastupdate['Sensor1 Notification']) > 3600 then
print('No data received for '..difference ..' seconds')
send_notification('Tom','No data received from sensor 1')
commandArray['Variable:Sensor1 Notification']='TIMER'
end 'Sensor1 Notification' is an Uservariable of the type string which has to be created first.
