Smarter Coffee & iKettle 2.0
Posted: Monday 15 August 2016 22:55
by trixwood
iKettle 2.0 & Smarter Coffee Interface for Domoticz
Source & guide:
https://github.com/Tristan79/iBrew
Screen Shot 2016-08-16 at 01.43.57.png (90.21 KiB) Viewed 5774 times
Re: Smarter Coffee & iKettle 2.0
Posted: Thursday 15 December 2016 4:31
by trixwood
Updated iBrew with trigger support & mini guide to integrate the ikettle and the smarter coffee in domoticz :-)
Posted: Friday 16 December 2016 18:23
by trixwood
Added windows support. No need to fiddle around with python or packages. Just use the exe ;-)
Posted: Monday 26 December 2016 12:04
by trixwood
Setting up iBrew for domoticz is very simple!
* 10.0.0.99 ip of iKettle!
* user:[email protected]:8080 domoticz connection string
ibrew domoticz user:[email protected]:8080 10.0.0.99
It will set up all your sensors automatically!
See github for more info...
Posted: Saturday 14 January 2017 21:38
by corederoma82
hi i have a question that I don't understood.....but the smarter coffee is functioning with domoticz?
Posted: Saturday 14 January 2017 23:05
by trixwood
Well, yeah! With a little bit of work... care and love, and probably some coffee :-)
All the sensors/values can be added with the previous command and and are updated with the ibrew server...
It creates for you the hardware, and the sensors... and the ibrew server updates them when changed in any way...
That is the automatic reading part..
For the control bit...
You still have to add actions manually to virtual switches in domoticz...
and calling ibrew rest api to switch things on/off, set cups etc...
so it needs a little tweaking...
Just add a new virtual switch
action: off http://ibrew_ip:2080/api/kettle_ip/stop
action on: http://ibrew_ip:2080/api/kettle_ip/start
and make
that a Sub/Slave of the busy motion sensor...
That should work... I haven't got around the test and map out, the control bit... not at home atm. :)
If you start the ibrew server have a look this page:
http://hostibrew:2080/info/api
it contains all the commands possible, plus you can test them there:-)
So it's semi-automatic...
Posted: Monday 16 January 2017 16:57
by corederoma82
trixwood wrote: All the sensors/values can be added with the previous command and and are updated with the ibrew server...
Hi, thanks for your answer, but whick commands?
Posted: Tuesday 17 January 2017 17:07
by trixwood
The reading part of the sensors use the above post:
http://domoticz.com/forum/viewtopic.php ... 77#p110655
after that run to run the server...
ibrew events web
Any bugs report on github :-)
or look on the github page,,,
Posted: Monday 30 January 2017 19:38
by corederoma82
But it's possible install it on Domoticz running on Windows?
Posted: Wednesday 01 February 2017 0:00
by trixwood
yeah! :-) there is a windows package... and you can run the setup from there (running ibrew.exe) :D
Posted: Tuesday 09 May 2017 22:03
by corederoma82
windows package is not more available.....
Posted: Friday 12 January 2018 19:07
by pazzje
I know, i am looking to for a copy... Who has one?
